Window stuck down, and ITS COLD!!!
Hey, I gotta nasty problem...
My window is stuck down about 6 inches or so. It used to be that it only went down 6 inches, but today it is stuck down. When I use the window switch, the motor just "barks" at me. I tried pushing the window up while pressing the switch, but that doesn't work either. Will this be $$$ to fix?
'83 HOmaro--doesn't run
'92 Bird--burnt to a crisp
'78 T/A 400--fast, Burt Reynold's style
'83 Buick LeSabre--the Ghetto Cruiser
"Without evil there can be no good, so it must be good to be evil some time!"
Probably not... Pull the door panel and see what you find. At worst its probably just a bad or failing motor. A new motor is only $20-25.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Drew
My Website
87 Iroc
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
But aren't at that price they remanufactured?I have seen new ones for $80. I have also heard that it is a two person job, mostly to keep the window from breaking. I am looking into it because mine is going out too.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Mike Kenny
The remanufactured ones run about $25-$35. New ones run around $75-$80. One person can do the job. Just cut a board to put inside the door to hold the window up, while you change out the window motor.
Car: 04 GTO
Transmission: M12 T56
Having just put a DS window motor in mine, i can say that at least in my case, i could have done it alone. I had my dad holding my window up, but about halfway through mutilating the last rivet holding motor to regulator he got sick of holding it and realized it wasn't going anywhere.
Here's a tip. It's a cake job to do if you hack all the sheetmetal in front of the motor out of the way. y car was a one owner car, and i got most of the receipts for warranty work over the years. The DS motor had been replaced before under warranty. When i got the doorpanel off, to my surprise, the monkeys that did the last RR had snipped all the sheetmetal out of the way. God bless 'em. If only there rivet gun didn't suck.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
SPEEDY Z28
Sep 15, 2015 05:34 PM
