Carbon fiber stuff
Old Dec 16, 2000 | 03:26 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Carbon fiber stuff
I was checking out the tech article on this and it sorta sounded like fiberglassing. Has anyone done carbon fiber? If so, is it like fiberglassing. I want to make some interior pieces, and was going to make them out of fiberglass, till I saw the article. Any help would be apriciated.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 16, 2000 | 06:28 PM
Monkie's Avatar
Next gen makes a CF interior set for all 3rd-4th gen cars I think. Its around $380. I was gonna get it but got other things to do first.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Kills:
95 (****) Probe GT
94 Mustang GT
91 CRX (dont ask me why he raced me)
2nd Gen Z28 (350) haha to you V8 guys!
1992 RS 305 TBI (good race)
More to come
Old Dec 18, 2000 | 01:47 PM
theformula's Avatar
wooddash.com has brushed aluminum and any carbon fiber color you want. $200 with the coupon code car-club10
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body, runners,intake manifold,cam, and heads.
Old Dec 18, 2000 | 02:02 PM
stingerssx's Avatar
I love to make stuff myself. I think just going out and buying stuff that I can do myself is not as good. If you saw my car, you'd understand.
Old Dec 19, 2000 | 04:47 PM
812MANY's Avatar
I made my own aluminum gauge cluster for $2.00 and an afternoon of drilling filing and grinding.
The carbon fiber materials are only about $50 and it sounds pretty easy.
Anyone that pays $300 for that stuff deserves to loose the $$
Old Dec 19, 2000 | 04:50 PM
812MANY's Avatar
As for quality, just take your time. What if it takes you 2 weekends to do it, you're saving a few hundres $$ and you can actually say you did it yourself.
Besides, if you're good at it you can do it for your buddies (for a minor profit) and recover your costs.
Old Dec 21, 2000 | 04:56 PM
stingerssx's Avatar
Hey Many, have you worked with carbon fiber? Some of the center console will be aluminum, and other pieces will be carbon fiber. What I need to know is, in the article it said something about foam. Well, I've never used foam when fiberglassing, and I might just want to cover some existing pieces with the carbon fiber. My situation is the interior is dead. I'm also changing from auto to stick. So some pieces need to be made, or modified enough to work.
Old Jan 10, 2001 | 09:14 PM
gt auto's Avatar
hey carbon fiber I mean real carbon is a lot like fiberglass but cost big $$$$$ and is harder to work with then glass but is much stronger and lighter then glass. There are diffrent grades of carbon. We are thinking of making some body parts out of good fiber but not sure if it will sell for the high $$$ they do have int. pcs. made from a carbon fiber look plastic and other meterials
Old Jan 11, 2001 | 11:42 AM
LV V8's Avatar
Do you have some pics of what you did?
The Car : 1991 Firebird V8 305 TBI, White, T-tops
IM : Shadwbeast
Old Jan 11, 2001 | 11:59 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I work with carbon fiber in the Navy. The carbon fiber cloth that we use is thicker and more difficult to mold than glass. It doesn't seem to want to conform to surfaces you apply it to unless you use a vacuum bag. The plus side is that you can probably use less plies than glass for whatever project you're doing and it'll be the same strength.
'89 Firebird Formula-
K&N Air Filter, Holley Throttle Body Air Foil, Hotchkis Strut Tower Brace, Hotchkis Panhard Rod, Hotchkis Trailing Arms, Kenny Brown Subframe Connectors, GT Auto Assesories aero wing
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
