Need to find Large Rivets for door panel
Old Jul 25, 2012 | 07:37 PM
Nyczbubba's Avatar
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
I am replacing the doors and I have to swap over the window motor and door lock solenoid. Those were originally rivetted onto the door. The rivets I found are too small. I can't seem to find a large enough rivet at any of the local hardware stores or auto parts stores. Any links that I can purchase online for these large size rivets?
Old Jul 25, 2012 | 08:02 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Need to find Large Rivets for door panel
Did you try NAPA? I'd go down to a local body shop and see if they have a few.
Old Jul 25, 2012 | 08:18 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
I never bothered with rivets. I always replaced them with nuts and bolts with lock washers. The rivets always loosen up anyways. And if you ever have a problem later it is much easier to take bolts out than rivets.
Old Jul 25, 2012 | 10:30 PM
Nyczbubba's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.47
I would do that if I can access behind the door as easily. Blind rivets would probably be easiest.
Old Jul 25, 2012 | 11:32 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I believe you are looking for 1/4" peel rivets. They used to be available from GM, but I'm not sure if that's the case anymore.
IIRC,the peel rivets are supposed to split apart and wrap around providing more support from behind.
Example:
EDIT: I found a thread with more information: https://www.thirdgen.org/forums/elec...rivet-gun.html
Old Jul 26, 2012 | 02:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.clipsandfasteners.com/
Old Jul 26, 2012 | 08:06 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Don't forget you need to borrow or buy the GIANT rivet gun to install them also !
I was lucky and my bud who works in a body shop brought me some giant rivets and
the giant gun to install them........................
Your little "housey" guy won't work!
Old Jul 28, 2012 | 01:20 PM
Nyczbubba's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.47
Originally Posted by mantaguy
Awesome Thanks!!
Anyone have and idea what size I would need for the door?
I have the large rivet tool, the one that looks like lock clippers
Old Jul 28, 2012 | 02:14 PM
Scorpner's Avatar
Engine: V6, V8
Originally Posted by Nyczbubba
Awesome Thanks!!
I believe you are looking for 1/4" peel rivets. They used to be available from GM, but I'm not sure if that's the case anymore. The peel rivets split apart and wrap around providing more support from behind.
Example:
Here is another post explaining peel rivets and the size commonly used:
https://www.thirdgen.org/forums/post...71-post16.html
Old Aug 19, 2012 | 09:43 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
i just ordered some i hope these work. i was having the same problem
Old Dec 2, 2012 | 01:12 PM
!CamaroDave's Avatar
Car: 87 Camaro IROC, 85 IROC Roadste
Engine: 5.7 V8 350 TPI, 383 - Coming Soon
Transmission: 700R4, Turbo 350
I know this thread is a few months old, but when I put power windows in my doors, I had to buy the rivets from the dealership and I rented a big rivet gun from the local tool rental center. The rivets were like $3 a piece.
Old Dec 2, 2012 | 01:40 PM
Car: 1984 T/A
Engine: LQ4
I have the rivets but all the tool places ive gone to dont have the big rivet gun
Old Dec 2, 2012 | 04:07 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
http://www.grainger.com/Grainger/riv...ecatalog/N-8mj
Old Dec 2, 2012 | 04:08 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
http://www.amazon.com/Heavy-Duty-Riv.../dp/B002HO6I1M
Old Dec 3, 2012 | 11:36 AM
Richboll's Avatar
Engine: 305 TBI
http://www.harborfreight.com/catalog...lt?q=Rivet+Gun
Old Dec 3, 2012 | 12:09 PM
82tarecaro's Avatar
Just be sure to buy the rivet with the correct grip. I found out the hard way that some of the regulator rivets have a longer grip, and they won't work when you are using them on thinner materials such as sheet metal.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
