Is She totalled????????
Old Jan 26, 2001 | 09:03 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Driving through a parking lot (10-15 MPH???) some women driver blows her stop sign and hits me. Smacks the front corner dead on, It doesnt look to bad but I need:[*] front passenger side fender,[*]passenger side headlight,[*] parking light,[*] hole bumper front thing,[*]cant turn without rubbing BAD,[*] passenger door wont open even 2 inches.[*] and looking at the car from behind the drivers side is about 2 to 3 inches higher than the side that got it.[*]also looking at front wheel wells there is now an extra 2-3 inches clearance on drivers side and none on the side that was hit.[*]
it looks like the frame (sub frame, uni-body whatever) is bent due to the drivers side being higher now. Is she totalled or do you think they will fix her, its an 86 firebird with a 305 and flowmasters, otherwise all stock.
[*]I kina want it to be totalled so I can get a T-Top trans am or formula.
86 Firebird, 305 4bbl, Flowmaster 80 series.
Sound System: Pioneer Head Unit, 2 Ground Zero 12" Nuclear Series Subs, Rockford Fosgate wiring, Crappy Amp untill July
Work to be done in July: New Engine (383 or bigger) New worked 700R4, power Sunroof, Kobel predator Body kit, Ram Air II hood, Rims, Tires, 1.5" lowering springs, and re-done interior...I want yellow and black but the 4th gen conversions look tempting, oh yeah painting it Yellow also
AOL screen name= madbiker1
Old Jan 26, 2001 | 09:48 AM
86IROCMIKE's Avatar
I would scrap it and get what you want
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,2:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER CD RECIEVER WITH REMOTE AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!
Old Jan 26, 2001 | 09:57 AM
86FyrBrd's Avatar
I want to but if the insurance company says its not totalled then I dont have the money to do anything besides keep it
[This message has been edited by 86FyrBrd (edited January 26, 2001).]
Old Jan 26, 2001 | 12:41 PM
FBODY-ADDICT's Avatar
If the chassis is really warped it is totalled, so start looking for that T/A-Formula-GTA.
Old Jan 26, 2001 | 01:26 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Based on your description, I would say that the insurance company will total it. Since it was the ladys fault, Make sure you detail everything that was extra to the insurance company. If you have special aftermarket rims, new tires, any engine dress up or anything, they compensate extra for those things.
I had an 86 Cavalier Z24 that caught fire in NJ. The insurance totalled it and I got an additional $900 out of em for proving that I had some upgrades that were lost.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Old Jan 26, 2001 | 01:46 PM
86FyrBrd's Avatar
I have my Flowmaster exhaust on it which came to about $200 and about $880 worth of subs in it, I got them for free. do I take them out or claim them with the car.
Thanx,
Brian
Old Jan 26, 2001 | 06:35 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
It's totalled. It sounds like it got hit right on the end of the bumper bar and both rails are bent away. If you want to keep it, buy it back from the ins.co. or have it written so it's just not totalled. With used parts and a set up on a frame machine it's a cheap end easy fix. 2-3 hours set-up and 2-4 hours pull time @ your local labor rate. That's stripped down before it goes to the frame shop. All you do is clamp on to the end of the damaged bumper bar and pull the rails back back to center. Stress relieve it, fix up any "chew marks" and measure it till it's within spec. Put on new bar and ready for sheet metal. Leave your (otherside) fender on and it'll come right back too. Your door that won't open is probably hitting the fender. Use a screwdriver to gently pry the fender over the door then open the door and pull the fender out.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
Old Jan 26, 2001 | 09:48 PM
leirch's Avatar
I would take all of your "upgrades" out and put back stock stuff in its place. I mean, damm, the insurance company already owns you. Screw them
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Check out the webpageHere
Old Jan 26, 2001 | 10:56 PM
86FyrBrd's Avatar
Ok new question...my exhaust survived the accident fine...the car was towed to the towing company, tonight I had it towed to my house, I thought my exhaust was hanging a little low, looked at it, the hanger is ripped off the pipes and now the pipes are all loose and wiggling in the clamps and all, should I claim my exhaust or atleast the pipes since it is less than a month old and ripped off due to the towing?
------------------[*] Some women driver blew a stop sign and totalled this cr last night86 Firebird, 305 4bbl, Flowmaster 80 series.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Nervous2
Oct 8, 2015 10:53 PM
jaridjohn
Oct 5, 2015 07:01 AM
david068513
Sep 18, 2015 10:36 AM
