need help with fender misalignment from jacking
Old Aug 28, 2012 | 08:29 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ok, i've never dealt with this problem before and i'm somewhat stymied. someone jacked this thing up wrong and the left fender now pokes out past the door jam. the hood rubs on the driver's side near the cowl and the clearance on the passenger side is perfect. i'm wondering how to get the right fender back in line with the passenger door without further closing the hood gap. included are some pics for advice on how to proceed. THANKS!
Attached Thumbnails need help with fender misalignment from jacking-imga0580.jpg   need help with fender misalignment from jacking-imga0581.jpg   need help with fender misalignment from jacking-imga0582.jpg
Old Aug 28, 2012 | 09:03 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: need help with fender misalignment from jacking
That's such a common problem, I can't help too much, other then i bent the seam back straight to get the bolt out, then worked the fender gently back in and bent the bolt hole to match up. it isn't as bad, but still is out a little. Need someone with more experience to chime in.
Old Aug 29, 2012 | 04:15 PM
87rattler's Avatar
Car: 87 Iroc-Z28
search "fender door alignment" lots of guys have had this problem and fixed it quite easily....for free.
Old Aug 29, 2012 | 09:19 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
I tried that search and came up with someone using a frame machine which isn't free. Can you post what topic mentions how to fix this for free? Both sides of my Camaro are like this...
Old Aug 29, 2012 | 09:53 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i used vise grips and bent it back simple solution i also did some minor bending to get it back to the correct bow i had the fender off laid it on the ground and pushed it back apart test fitting along the way to see if it fit
Old Aug 29, 2012 | 10:22 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
IIRC,
Loosen the bolt at the bottom of the fender, & the bolt(s) in the door jamb
Carefully bend the flange back into shape.
I recall there being a tread that went into detail.
If I find it I'll post the link
Old Aug 29, 2012 | 10:27 PM
Car: '87 Camaro
Search-
Cost of repair jacking damage
Started by member-
58mark
Sorry I can't link front my phone but that's the thread you want to read
Old Aug 29, 2012 | 11:13 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just grab it with 2 pair of widemouth visegrips and bend it strait back down. Its not hard at all. I've even had to use a long 2x4 and hammer to get it back into place but it doesnt hurt it at all.
Old Aug 31, 2012 | 07:03 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
OK.... i went under there with sundry tools of destruction and began making noise. the seam was totally smashed flat but eventually i got it straightened back out. it was then that i realized that the fender was bowed horizontally and it all made sense. -previously i thought it had a vertical bow.- so then i started banging the fender at the door seam with a sledge and piece of cork gasket material and the fender is now acceptably in-line with the door..... now i could start looking at the hood fitment.... the drivers side was rubbing on the fender near the door and i had about a 1/32" that i could shim the hood toward the passenger side fender. i installed a couple of washers and voila, hood now doesn't rub. so i fixed two BIG problems, rerouted some vacuum lines and hooked up the PVC, all in about 75 minutes... now i can seriously think about painting, The Beast. i fired it up again today and it sounds great.
Old Aug 31, 2012 | 08:38 PM
red rock's Avatar
Car: 1987 iroc
Makes ya feel all fuzzy inside when you fix your own problems don't it?
Old Aug 31, 2012 | 08:58 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
yes, especially when you have three projects going at once and sundry other home fixes on the agenda. i was glad it was a fast, easy job....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
z28joe2
Sep 28, 2015 05:54 PM
roysatikas
Sep 22, 2015 08:15 PM
