aftermarket spoiler/wing
Old Sep 3, 2012 | 10:28 PM
thaemcee2's Avatar
Car: 1989 Trans Am GTA
Engine: L98 350
Hey guys my 89 GTA had a fiberglass reproduction wing installed by a reputable body shop, I am not too sure the name of manufacturer but I believe it was purchased through Hawks.
Anyway, the sides of the wing that should be right on the edge of the glass on the hatch, is about 1/2" high and just doesnt look right. I attached a photo to show what I am talking about. Basically, the line of glass right above the gas tank shouldnt have the gap that mine has...there shouldnt be much of any gaps at all.
There are clips visible and while some of them appear to be on as they should, the black rectangular clip furthest to the front of the car doesnt seem to be clipped in. It does have the "play" to be moved to where it should be, but the clips dont allow it to stay there. maybe I should have my body guy take the thing off and put it back on properly with the clips adjusted? what do you guys think?
Attached Thumbnails aftermarket spoiler/wing-gta-1-1.jpg
Old Sep 3, 2012 | 10:32 PM
Guest
Guest
Posts: n/a
Re: aftermarket spoiler/wing
Take that fugly thing off. Problem solved
Old Sep 3, 2012 | 10:38 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
You paid someone to put it on, if its not right take it back and say fix it. But be nice when you say fix it.
Old Sep 3, 2012 | 10:48 PM
thaemcee2's Avatar
Engine: L98 350
Gee, thanks bud.
Should I put on a Camaro spoiler? Or not have a spoiler at all on a TA?
Old Sep 4, 2012 | 01:40 AM
Marine_Marauder's Avatar
Car: Black 1991 Z28
Engine: 5.7 TPI
Transmission: Automatic
Axle/Gears: I have no Idea
Originally Posted by thaemcee2
Gee, thanks bud.
There are a few spoilers that look good on TA's, I recently saw a high rise 91-92 Z28 spoiler mounted on one that looked pretty good, but the stock "Wraparound" style is double fugly IMHO.
Old Sep 4, 2012 | 01:46 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Take it to the shop and have it fixed how it should be and get them to do it right the first time, I'd be in a fit of rage because I only expect the Very Best for my car.
Old Sep 4, 2012 | 09:14 AM
thaemcee2's Avatar
Engine: L98 350
Guys I am sorry if you don't like the stock OEM wraparound spoiler that comes on Trans Ams. I would rather leave my car as it is now than put on anything other than the original spoiler/wing on the car. I personally think the Camaro spoilers are gross on my car.
I posted the topic to see if anyone knew what I could do short of going to the body shop to have them do it.
So no one out there has experience with the aftermarket wings on these cars? Or knows enough to explain how I could fix this myself?
Semper Fi
Old Sep 4, 2012 | 09:43 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I intend to do two one for each car but haven't yet so I can't help you. I would like to know what you do to fix it so keep us posted.
Old Sep 4, 2012 | 09:26 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Ignore everyones opinion on your spoiler, its your car and you do it your way, my grandma always says, opinions are like a$$holes everyone has one and they all stink.
Old Sep 4, 2012 | 09:54 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
thaemcee2, what kind of clip did the body man use? me and a friend ran screws into the recesses where the clips "would" go on the factory wing and measured how far back/forth and in/out we wanted the screws and made a mark on the body and transferred that measurement onto the wing.
after we had the placement of the wing setup and screws in, we worked with how it sucked to the glass and mine is pretty tight to the glass.
this is just after we mounted it. if you need better shots lemme know.
Old Sep 5, 2012 | 10:38 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
Semper Fi
You could try forming it to your car with heat if the wing is misshapen. I've never done it personally, but I've seen it done, I guess it depends on what the wing is made out of. I can't really tell from the pictures you posted exactly how it mounts or how to adjust it. It could just be that the guys who mounted it didn't know how it was supposed to look when they were done with it and mounted it wrong. You won't know unless you dismount it and see if rests flush with the hatch without being bolted on.
Old Sep 5, 2012 | 01:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I just had one installed and my body and fender guy just used the clips it came with.
Old Sep 5, 2012 | 01:43 PM
82tarecaro's Avatar
The clips that come with it suck. You can use the original mounting tab and add stainless steel screws to mount it.
Read this thread for more info.
http://www.turbotransam.com/forums/s...oiler+mounting
Old Sep 5, 2012 | 10:16 PM
thaemcee2's Avatar
Engine: L98 350
great stuff..exactly what I need thanks
Old Sep 5, 2012 | 11:14 PM
Fordvette's Avatar
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
I like the Firebird one so much I used it on my camaro
Old Sep 6, 2012 | 01:27 PM
mantaguy's Avatar
Engine: 5.0 EFI
These spoilers from Hawks don't come with mounting tabs,It's just as easy or easier to use the hardware it comes with.Whoever installed that guys,did it wrong.
This is where the shop located those clips on the spoiler,how they go on to the hatch,I don't know,the guy that installed it was not their.I'll try tomorrow again.
Old Sep 6, 2012 | 02:00 PM
mantaguy's Avatar
Engine: 5.0 EFI
Semper Fi
The only guys that don't like them,don't have one.I'm going to the shop today and I'll take a pic of mine and I'll post it so you can see what they did wrong,I'm sure your guy will fix it the way it's supposed to be.
Old Sep 6, 2012 | 02:43 PM
82tarecaro's Avatar
I have the clips on mine. I bought the car with the wing already installed. While my spoiler lines up where it should, I don't think the clips are sturdy enough. When I get the opportunity, I want to take the wing off and use the screws to mount it. You have 3 mounts per side as opposed to 1. I can grab the ends of my wing and move them around. It is not that secure.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
