drivers door hard to close
Old Oct 1, 2012 | 09:38 AM
boxxed's Avatar
Car: 1988 Black GTA
Like the title says, the door is hard to close. I have 1988 GTA. I kinda have to slam it. It there an adjustment that can be made? Also, the door sags a little bit and has started to wear in the sill jamb..
Old Oct 1, 2012 | 10:09 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: drivers door hard to close
There is a door alignment tool. My uncle has one, we used it to align my doors recently, works great.
Google "door alignment tool"
Top link: http://www.eastwood.com/e-z-store-do...ment-tool.html
Old Oct 1, 2012 | 10:24 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Replace the hinge bushings and pins to eliminate the sagging and rubbing on the ground effects. Then take and loosen the door striker bolt and set it to match with the door latch height and proper depth. Lubricate the hinges. If you just adjust the striker bolt then the door will still sag and rub on the ground effects.
Old Oct 1, 2012 | 10:49 AM
boxxed's Avatar
Car: 1988 Black GTA
Ok thanks for the info.. Where is a good place to get the parts?
Is this what you are talking about?
http://www.ebay.com/itm/82-92-Camaro...sories&vxp=mtr
Old Oct 1, 2012 | 12:40 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
That's them. Not sure about the quality of those. I purchased a power window regulator from them that lasted two months.
Old Oct 1, 2012 | 12:56 PM
boxxed's Avatar
Car: 1988 Black GTA
Hmmm, ok what about this? They are 4 times the cost. http://www.hawksthirdgenparts.com/pr...r-Pin-Kit.html
This is pretty new to me and so I am not sure the best place to get parts..
Thanks for your help..
Old Oct 1, 2012 | 01:20 PM
jas2730's Avatar
The difference between those is the bushings from hawks have grease fittings. They should last alot longer. Are they worth the money? That's for you to decide.
Old Oct 1, 2012 | 01:28 PM
jas2730's Avatar
Also, I can tell you that I have the grease fittings on my vert and they are now sagging and need replaced. So they don't last forever.
Old Oct 1, 2012 | 01:55 PM
91phoenix's Avatar
I believe Lon at Top Down Solutions has the parts also. His may be a little higher though.
Old Oct 1, 2012 | 02:42 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
I have used the parts from TDS. Top quality. Doors shut like new!
Old Oct 1, 2012 | 07:43 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
VERY pricy - but worth it!
http://www.top-downsolutions.com/Bod...t-%28deluxe%29
Old Oct 4, 2012 | 07:11 PM
munk20's Avatar
Car: 1991 Z28
you can also get Dorman part number 38401 from rockauto.com which is 6.68 and comes with the upper and lower pins and bushings for one door
Old Oct 4, 2012 | 08:07 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
just installed the Hawks door pin kit last week, think they are made by TDS...Fixed my issues, that with new weather striping around the door got rid of my rattles. Hawks/TDS also sell pin kit without the grease fittings for $75. I wouldnt cheap out and use that ebay kit. The upper factory pins need to be grinded off. That was anothe $200 intalled at body shop
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
chevyguy1999
Aug 16, 2015 08:49 PM
tecustomz
Aug 16, 2015 02:28 PM
