shifter knob
Old Mar 25, 2001 | 05:49 PM
kyle86firebird's Avatar
shifter ****
How do you remove the gear shift **** on a manual 86? And will one of those flameballs fit on it?
Old Mar 25, 2001 | 06:08 PM
MNformula350's Avatar
Just unscrew it counter clockwise.
84 FIREBIRD-(undergoing rebuild)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top
WANTED:82-84 Firebird 2.5 4cyl,4spd-Just Cause
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Mar 25, 2001 | 09:18 PM
Anti speed-limit's Avatar
Alright ill tell you how to unscrew your shifter ****. First ting is your take out your carberator, after you have done this take your dash out. Now this will give you some room, now drop your tranny. Now you are ready to remove your shifter ****. All you have to do now is turn it. After this you can then screw on your fireball. Now make sure you put everything back in place, and you should be set.
Old Mar 25, 2001 | 09:29 PM
odin65's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Anti speed-limit:
Alright ill tell you how to unscrew your shifter ****. First ting is your take out your carberator, after you have done this take your dash out. Now this will give you some room, now drop your tranny. Now you are ready to remove your shifter ****. All you have to do now is turn it. After this you can then screw on your fireball. Now make sure you put everything back in place, and you should be set.</font>
That's "CARBURETOR".
Old Mar 26, 2001 | 06:52 PM
alright my car is in pieces and the flameball is in the mail
Old Mar 26, 2001 | 11:31 PM
86IROC's Avatar
I had this exact same problem. That shift **** is on there REAL GOOD believe me. What I did was I took a large vise grip and gripped the ****, then I put the other on the shaft. And then twisted it off. Watch out cause this can scratch up your shaft. Hope this helps.
Old Mar 27, 2001 | 05:09 PM
92RSMAN's Avatar
86iroc that was a very proffesional answer unlike the others lol
Pure Black 1992 RS Camaro
CHECK OUT MY SITE! http://www.angelfire.com/ne/92rscamaro/index.html
Old Mar 27, 2001 | 05:40 PM
Fastcamaro87's Avatar
86iroc says "this can scratch up your shaft."
wouldnt want this to happen
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Mar 27, 2001 | 06:06 PM
deacon17's Avatar
Spray WD-40 underneath it, let it sit awhile, then use one of those rubber things you use to open jars for grip. Apply heat with a hairdryer to loosen it up if that doesn't work.
[This message has been edited by deacon17 (edited March 28, 2001).]
Night rider327
Feb 25, 2016 09:50 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
