rear hatch is leaking bad!
Old Mar 26, 2001 | 06:03 PM
jayman350's Avatar
Hey everyone,
We had a bad rainstorm here a couple of days ago and I noticed my rear hatch was leaking really bad at the top(right behind my back passenger seat) I checked the weatherstripping and it isn't cracked or pulled up anywhere. The only thing that I see that might be a problem is the plastic pieces are separated where is it leaking from. Would some silicone stop this? Any help is appreciated.
Jay
black 85 Z28, t-tops, 4bbl carb, flowmaster 80 series muffler w/ custom tips (hollowed out cat), edelbrock chrome air cleaner, Infinity 4" 2 way front speakers and Infinity 3 way 6x9s, Alpine CDA-7863 head unit. many more mods planned (holley carb 4160 and edelbrock performer intake coming very soon)
Old Mar 27, 2001 | 03:09 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
Silicon bead across the rear hatch from 1 side to the other....my recommendation...
Old Mar 27, 2001 | 03:23 PM
RGZWS6's Avatar
Are you sure it isn't your T-Tops?????
Thats an odd spot to have a leak from your hatch. If it were, I would think that the water would run down and pool at the rear of the hatch instead of at the top (back of rear seat).
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Mar 27, 2001 | 05:39 PM
jayman350's Avatar
no it isn't the t-tops I looked right at it as it was dripping. The place that it is leaking isn't even connected to the t-tops. thanks for the suggestion though
Jay
Old Mar 29, 2001 | 12:43 PM
RGZWS6's Avatar
I don't doubt you. But, when I suspected my latch was leaking I tore all of my plastic trim off to see what was what. What I saw was the sheet metal from the roof (t-tops) runs all the way back to the hatch. When my tops would leak, the water ran down the sheet metal past the tops and out of the screw hole that held that long piece of plastic in place. The same piece that covers the hatch bolts. The guy who owned it before me even caulked those bolts thinking that that was where the leak was.
89 Formula 305 TBI
Old Mar 29, 2001 | 01:51 PM
KlayBuRn's Avatar
i used to have the SAME leak, it stopped when i replaced the black bar underneath the t-tops...
had nothing to do with the hatch area at all...
Old Mar 29, 2001 | 01:54 PM
RGZWS6's Avatar
KlayBuRn,
How big of a pain was that? I tried to get one out of a donor and just gave up. There was now way to get to it without damaging the weatherstriping.
How/where did you get yours?
89 Formula 305 TBI
Old Mar 29, 2001 | 03:15 PM
jayman350's Avatar
I will check that out. I didn't think about it running along that piece to drain. Oh well I guess thats what i am doing this weekend. Thanks
Jay
Old Mar 31, 2001 | 04:58 PM
nestz28's Avatar
Just a thought- make sure the water is not coming from where the hatch bolts to the car. I had the same thing happen to me and it turned out to be water coming around the bolts. I just took the nuts off and put sealer in and the problem went away.
Old Apr 4, 2001 | 05:10 PM
CaptainW's Avatar
Look at the rubber stopper at the end of the hatch and make sure it is screwed tight to the hatch. My trunk leak like hell because the stopper got loose somehow and the hatch could not compress the weatherstrip tight enough. After I tighten the stopper - the leaking was gone. Hope it helps..
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
