Help!! A cop broke my doorlock!!!
Old Apr 15, 2001 | 03:32 PM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
I locked the keys in my car and he used a slim jim to open the door. When I got home I noticed that the lock would no longer unlock, when I put the key in it just kept turning w/ out unlocking the door. Any suggestions on how I can fix this? Any help is appreciated, thanks.
91 metallic blue RS flowmaster exhaust, sportline springs, K&N filter, much more to come soon
Old Apr 15, 2001 | 05:11 PM
camaro6spd's Avatar
HERE IS A GOOD IDEA FOR THE NEXT TIME...
get a zip tie, and zip tie the key to a place uder the car on top of something, like a crossmember or up and in the bumper etc. My dad, brothers and I do this and we have yet to need to get a slimjim or something eles.
Old Apr 15, 2001 | 06:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Or just put a key in your wallet.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 15, 2001 | 07:13 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
Take your door panel off so you can see for yourself what the problem is. You won't know exactly and neither will anyone else until you look. Don't know what else to tell you except the linkage that attaches to the lock cylinder probably came off. Whether or not it's broken or can just be hooked back on is anyone's guess until you look to see. Good luck.
Old Apr 15, 2001 | 07:15 PM
89ragtop's Avatar
https://www.thirdgen.org/messgboard/...ML/001568.html
Actually, one of the next threads down explains the process of removing the panel.
Old Apr 16, 2001 | 12:54 AM
Red Demon's Avatar
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
</font>
though I keep mine in my wallet that is an interesting thought.. just incase you are wearing khakis and drop the wallet too
hehehe
Hey feel free to chat with me on AOL IM if you wanna.. Darkhal2000! Also if you wanna join my webring gimmie a yell at my email addy. I'm always looking for third gen's to add.
My site, http://www.personal.psu.edu/users/j/m/jmj211/index.htm
Old Apr 16, 2001 | 01:27 PM
Brad's Avatar
Regarding the broken lock, the cop probably just accidentally knocked the rod that connects to the door lock off. That is what the slim jim makes contact with to open the car. It slides in and pushes down on the rod that goes from the lock to the door mechanism. It's a simple fix, except for the pain in the butt of getting your hands inside the door to put the hook of the rod back on to the lock.
Old Apr 16, 2001 | 04:40 PM
86ZRICHIE's Avatar
hopefully it's just what has been said, the linkage came out, but if for some reason it's the lock tumbler that broke, don't worry, just go to a junk yard and get a new tumbler mechanisim, you can have it rekeyed to match your existing key and install it again.
Old Apr 16, 2001 | 04:42 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Thanks for the help. I think that he did just disconnect the cable, that would explain why I hear a rattle in my door when I go over bumps. I kinda figured it would be something that is harder to get to than fix.
Oh yeah, I got one of those magnetic key boxes and hid an extra key under my car, so I won't have to worry about it happening again.
Old Apr 16, 2001 | 07:23 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Brad, be carefull with a magnetic hide a key. You know how our cars ride and many times they don't hold over hard bumps. I lost two before i started using duct tape to tape the key in my secret location. I also hide an ignition key in the car in case i loose my key's altogether, i can still drive away.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Old Apr 16, 2001 | 10:19 PM
theformula's Avatar
I cant believe some of you are posting where you hide your keys on your car ....on a public board!
Old Apr 16, 2001 | 11:33 PM
mycarsucks's Avatar
We have key boxes on all of our vehicles that are supposed to be in a similar place on all. It takes me about half an hour to find the ones that my dad placed. So, its not all that bad to tell people.
Old Apr 17, 2001 | 01:00 AM
Keith5's Avatar
Car: C1500
I just keep extra keys in my wallet. I've done that ever since I've been driving. I lock myself out all the time.
Old Apr 17, 2001 | 11:58 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
My favorite is putting a spare key in your wallet and leaving your wallet in your car when you lock your self out. That sucks.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 17, 2001 | 03:21 PM
86ZRICHIE's Avatar
The guy I bought mine from put one in a hose that he put underneath the gas filler and hid with a piece of tape. I'm guessin he forgot it cause I didn't even notice it until I was repainting it.
Old Apr 17, 2001 | 09:17 PM
ScreaminDeamin85Z's Avatar
you can always use a speaker magnet the one i had was on there for 3 years and up until my wreck it never came off,i guess it takes a 45 mph collision to knock it loose.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Apr 17, 2001 | 11:42 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by 3RDGENFRANK:
</font>
I never leave my wallet in my car, it stays with me.
Old Apr 18, 2001 | 11:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I haven't done it, but I heard of the duct-tape-a-key method with a twist on it- spray the duct tape and the area around it with undercoating, so it blends in to the underside of the car.
My key's in my wallet, next to my .. uh... hm, maybe that's not a good spot for it!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
