steering wheel....pics inside
Old Apr 10, 2001 | 09:54 AM
jeff's Avatar
All right guys, my steering wheel on my 92 bird is coming apart on the right hand corner. Can this be fixed or do I need to buy a new wheel? Also, how much does one of those go for? Here's the link
www.angelfire.com/indie/jeff/HELP
http://www.angelfire.com/indie/jeff
1992Pontiac Firebird.
305 TBI
Metallic green/grey
T-tops
Still researching to find kick *** 350 for it.
Old Apr 10, 2001 | 11:20 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
That looks more like your airbag coming apart - not the wheel... If you "shop around" you can probably come up with one here on the board. Good luck...
KAM
Old Apr 10, 2001 | 02:08 PM
JPrevost's Avatar
Car: 91 Red Sled
I think they all are doing that. Mine is doing the same thing. When I took the air bag off I tried to pull it back over but the rubber just popped right off with a few minutes of driving. There must be a way to heat it up gently (air bag remember) and pull it back into position. Anybody done this?
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 10, 2001 | 10:31 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
EVERY thirdgen with an airbag I have ever seen has this problem, even mone. I don't think there is any hope.
Old Apr 10, 2001 | 11:38 PM
jeff's Avatar
screw that. there has to be help. i will not stand for this. i'll replace the whole damn thing if i have to.
305 TBI
Metallic green/grey
T-tops
Old Apr 11, 2001 | 12:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
my camaro is doing the same thing, it must be something to do with the air bag, i am wondering if you could just pull it up, and put a small dot of superglue on it, to hold it up, the souldn't cause any problems with the air bag deploing i would think..
just a though though.
Old Apr 11, 2001 | 06:05 PM
FORD Rustangs -R- Us's Avatar
prolly not, the **** goes out at a couple hundred MPH..i dont think itll keep a little superglue will keep the airbag from coming out..accually thats prolly what they used in the first place ... hmm...
Old Apr 11, 2001 | 06:39 PM
Vision's Avatar
Mine looks the exact same way (92RS). I just never made a big deal about it. However, if I recall I read a car review before buying my car, and I was under the understanding that our cars did not come with air bag. That it was until the 93 that came with single air bag, and 94 and up with dual airbag. I mean I know it looks like it has one but does it? I never knew, guess I'll have to get it checked now cuase i don't think it's good for the system (migt fail you know).
Old Apr 12, 2001 | 05:06 PM
MikeDwhoROCZImports's Avatar
Yes, it does have an airbag. I believe in 90 or 91 they started getting them, whatever year the steering wheels started looking big and fat (like that).
Old Apr 12, 2001 | 05:40 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yes they do have airbags,
on my 90 RS, there was a warning on it when i bough the car, (on the driverside sun visor) warning about the dangers of the airbag opening, and some saftey percosions to take.
I am sure someone still has there saftey warning on, and could post a pic?
Old Apr 19, 2001 | 01:20 PM
FBODY-ADDICT's Avatar
I have the same problem with my formula, Im just gonna get a Grant wheel for it and thats it, I saw the challenger series wheels( which look a bit like ours and have an available pontiac logo insert for the horn button ) for like 60 something, plus 30 something for the installation kit. I've seen used firebird steering wheels for 60 bucks, so im going with Grant.
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
punkmaster98
Sep 8, 2015 09:45 PM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
