92 formula wing on base bird
Old Nov 15, 2012 | 10:51 PM
89Formula3's Avatar
Car: 91 Firebird
Transmission: 5 speed
my buddy is looking to install a 91-92 formula wing on his base 92 bird. Does anyone know if the holes on the hatch from the base wing line up with the formula wing?
Old Nov 16, 2012 | 07:09 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: 92 formula wing on base bird
They don't. Formula wing has 2 holes in the deck, 91-92 has 4, none line up, and the clips on the glass trim are different too.
Take a look at the inserts on the 91-92 wing as well. That part of the wing is plastic and the bolt inserts are often missing or loose. They will probably need to be glued back is place.
There was someone else looking for this info as well, I'm going to post a pics of the two hatches today now I can get out to them.
Old Nov 16, 2012 | 07:13 AM
stealtht/a's Avatar
Oops, sorry, got mixed up in my wings. I think one hole on each side might match the regular straight wing,I'll check that out too. You will still be missing the clips on the glass trim.
Old Nov 16, 2012 | 08:59 PM
89Formula3's Avatar
Car: 91 Firebird
it's a base 91 92 Firebird Wing. so it won't line up with the 91 92 formula wing right ?
Old Nov 17, 2012 | 08:06 AM
stealtht/a's Avatar
I know for sure they don't line up completely, but I think one hole on each side does line up.
Sorry it's taking me so long, I really will go get some pics of the different mounting holes as soon as the frost melts!
Old Nov 17, 2012 | 08:25 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
The holes are different from wing to wing / hatch panel...
I would just switch the whole rear glass & hatch panel...
If you're trying to remove that Aero 92 Formula wing in 1 Piece, good luck... Plus the metal trim around the glass has additional metal tabs welded to it...
Save some time and just switch the hole glass & hatch...
I'm speaking from ""Experience".... It's what you get when you don't get what you expected"
Raf
Old Nov 17, 2012 | 10:28 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Raf
Yep, life is easier if you listen to people with experience, but not nearly as convincing as getting your own. It's only experience if you use it to adapt your behavior. If you keep doing something and continue to expect a different outcome, then you are insane.
The "you" here is not specifically you of course.
Old Nov 17, 2012 | 11:46 AM
89Formula3's Avatar
Car: 91 Firebird
I hear you guys. The hatch thing might just be a better idea. Thanks.
Old Nov 17, 2012 | 12:29 PM
stealtht/a's Avatar
i learn something new everyday in my junkyard.
i knew they had different holes, but i was mistaken in my beleif that all hatch panels were the same , just with different holes in the deck. for example you can see on the black panel (86 TA w/ wrap) that it has the cutouts for the reg wing and wrap wing. i thought the red panel (91 formula) would have the same deal, but you can see this one has no cutouts for the straight wing mounting.
from rough measuring, it looks like the rear holes for the wrap wing would line up with the staright wing holes, but thats it.
Anytime you switch wings it will be easier with the whole hatch swap, hatch swapping is super easy.
also, have you removed the 91 wing from the deck yet? you may find it difficult to do without damaging the wing.
Attached Thumbnails 92 formula wing on base bird-hatchpanels-005.jpg   92 formula wing on base bird-hatchpanels-011.jpg
mrestrictrplate
Sep 21, 2015 11:24 AM
90formulaVortec
Sep 8, 2015 12:42 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
90formulaVortec
Sep 7, 2015 06:54 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
