Got a freakin run in base coat
Old Nov 18, 2012 | 05:36 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I got a run in my base. I also had a small spot that i had to spot primer and it is showing threw the base. On the run i assume i just need to sand with like 800 and recoat? And for the primer show threw will my next coat cover it up?
with this should i just be able to block it with 800 or do i need to shoot a sealer on it?
Paint went on super good i just got too much on it.
Old Nov 19, 2012 | 04:57 AM
monsterjam5000's Avatar
Re: Got a freakin run in base coat
wet sand it smooth and shoot on another coat over the run and light spot and youll be good to go
Old Nov 19, 2012 | 05:30 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Did you clear over the run? If so, wet sanding it won't do anything unless you base it again. Need more info.
Old Nov 19, 2012 | 03:12 PM
Brando5641's Avatar
No i didnt clear over it. I got it fixed. I hit it with 800 and then layed down another coat.
Old Nov 20, 2012 | 01:12 AM
williamj218's Avatar
Yüz Germe
It is a absolute adequate info. Acknowledgment for administration your cavalcade with us.Keep autograph abide with added updates.
Old Nov 20, 2012 | 05:51 AM
MYFIRSTZ's Avatar
Car: 1987 IROC-Z all stock (sold)
Engine: 1987 T/A (current project)
Re: Yüz Germe
I agree wholeheartedly!!!
Old Nov 20, 2012 | 06:05 AM
LHernandezJr's Avatar
Re: Yüz Germe
ROTFLMAO!
Old Nov 20, 2012 | 06:57 AM
Brando5641's Avatar
Yea.....
Old Nov 20, 2012 | 05:01 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
I believe william probably used a translator per the post title "Yüz Germe." Unfortunately, it doesn't say what he probably meant to say. I know when I try to use translator to talk to some family in Mexico, it comes out all F'ed up. So, I just have my wife do it for me.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
89fast5oh
Sep 27, 2015 09:04 PM
