How do you get the shine ?
Old Apr 22, 2001 | 09:53 PM
Synergy's Avatar
Got a fairly simple question... after you paint a part and sand it down, even after going with 2000 grit... the paint still has no shine whatsover. How is the shine achieved after all that is done ? With a buffer ? Some sort of compound ? More sanding ? lol what ? Thanx
p.s. I'm trying to repaint the front spoiler since the paint is full of chips everywhere!
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Apr 23, 2001 | 12:20 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
3M makes a very good rubbing compound for use after 2000 grit sandpaper. It has really brought out the shine on everything I've used it on. I've always used it by hand but it can be used on a buffer as well.
Old Apr 23, 2001 | 01:02 PM
Cam350TBI's Avatar
Did you apply the clearcoat and still no shine? If not, spray a clearcoat on. The paint is not what gives you the shine...its the clearcoat. Check you local car paint store (ie PPG) they can help you out.
Old Apr 23, 2001 | 04:07 PM
Ringmaster72's Avatar
Car: 1989 IROC
After you sand down the clear with 1500 or 2000 grit you should go over it with a buffer and PERFECT IT III compounds by 3M. You need a cutting pad for the first few coats with the cutting polish, then you need a softer pad to do a final coat with swirl remover, also PERFECT IT II by 3M.
Old Apr 24, 2001 | 07:02 AM
85firechicken's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Cam350TBI:
Did you apply the clearcoat and still no shine? If not, spray a clearcoat on. The paint is not what gives you the shine...its the clearcoat. Check you local car paint store (ie PPG) they can help you out. </font>
I don't have clearcoat and my T/A nearly glows in the dark! You need to use a GOOD polishing compound and follow it up with some GOOD wax! My personal favorite is Liquid Glass. It looks great, but is a little on the expensive side for wax. But you get what you pay for.
1985 Trans-Am: GM Goodwrench 350 (basically stock except for the heads); Newly rebuilt 700R4 w/B&M Shift Kit; B&M Ratchet Shifter; Holley 750; Edlebrock Performer RPM Intake; Hooker Competition Headers; MSD Ignition; K&N filters everywhere; Whatever gear ratios came stock with the 85 T/A (it at least has Posi); Maybe some other mods that I just haven't noticed (I just bought it in Feb '01); work in progress...
[This message has been edited by 85firechicken (edited April 24, 2001).]
Old Apr 24, 2001 | 06:52 PM
Cam350TBI's Avatar
Isn't wax just another "clearcoat"...that wears off. I agree w/ a good compound but still the clearcoat gives you the "shine". And you dont have to apply it every month like wax.
Old Apr 24, 2001 | 06:54 PM
Cam350TBI's Avatar
BTW, i'll try the "LIQUID WAX" next time I wax. Thanks!!
Old Apr 25, 2001 | 08:51 AM
With Liquid Glass (or any other quality wax), you only need to apply it once a year if you properly maintain it (regular washing/polishing), and that little bit of extra effort pays off HUGE dividends. You can draw a bigger shine from waxing/polishing than you can from these new-fangled clearcoats. Maybe I'm just old-school, but so are the guys at the car shows!
Old Apr 25, 2001 | 09:54 PM
Belker's Avatar
I recenty sanded my hood with 1500 grit and it was definately dull. I then polished it with Meguiar's Deep Crystal System Polish. It made the hood shine line glass. Incredible. It is far easier to use than a standard polishing compound (by hand, at least). It is actually marketed at step #2 in a three step paint care system: (1) paint cleaner, (2) polish, (3) wax. I highly recommend the Meguiar's product line. It's even easily obtainable at Walmart or autoparts store.
Street Lethal
Apr 30, 2019 12:14 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
RacerM
Sep 28, 2015 04:25 PM
neilb
Sep 15, 2015 05:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
