85 T/A Seatbelts
Old Apr 28, 2001 | 06:06 PM
Transamchk's Avatar
Car: 1985 Trans am & 2007 Grand Prix
85 T/A Seatbelts
I own an 85 Transam. The 85's have a factory recall on the seat belts as they sometimes do not retrack after they are fully extended. My driver's side belt has this problem. The dealership ordered a replacement seatbelt for me, however, the only color available now is gray and my interior is black. Does anyone know where I can locate a new black seatbelt for this car? As a last resort, I have a junkyard seatbelt, however, I am concerned I may run into the same problem if I install this belt. Any suggestions would be appreciated
Old Apr 28, 2001 | 07:47 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
what color gray? When I had my IROC recall done, they gave me 3 gray and 1 black because there were no more gray driver side buckles. I'd HAPPILY trade you if you have the light gray color.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 28, 2001 | 08:01 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Hi CHK, the buckle covers pop off and can be changed over. Black is easy. You can get them dyed or have your original belts re-wound into the new mechanism.
Good luck
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Old Apr 28, 2001 | 08:38 PM
Transamchk's Avatar
Jim85IROC - I believe the color I have is the light gray. I wasn't aware there were other tones of gray. How will I know it's the right color? I will gladly swap with you if it's the color you're looking for! That is the best news I have heard in a LONG time Please let me know how to determine if it's the right color.
Old Apr 29, 2001 | 09:07 AM
Tom Batts's Avatar
I'm in the SAME boat... mine won't retract either. I think TACREATIONS has some...
Old Apr 30, 2001 | 09:09 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Is it the front belts or the back ones? My back passenger side belt won't work. It is light gray also. Is this covered under the recall? What do I need to do to get it fixed if it is?
Old Apr 30, 2001 | 05:21 PM
Transamchk's Avatar
Unfortunately, I don't think the back belts are covered under this recall notice. I will forward you a copy of the recall notice via email. It will be from MsHilara@aol.com. Good Luck
Old Apr 30, 2001 | 05:25 PM
Transamchk's Avatar
Well I would send you the info but I just realized you don't have an email address listed..Oops! Here is the URL http://www.nhtsa.dot.gov/cars/proble...ls/recmmy1.cfm
Old Apr 30, 2001 | 09:00 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
[This message has been edited by Eric's85TA (edited May 01, 2001).]
Old Apr 30, 2001 | 09:06 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks, I checked the site and it doesn't look like that is covered.
2012sergen11
Oct 13, 2015 07:38 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
FormulaEngland
Sep 30, 2015 01:50 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
