89 front on 92 possible?
Old May 2, 2001 | 10:59 PM
firbird's Avatar
Is it possible to use an older style front nose panel on a 92 firebird? The reason why is because I do not like the front end style as much as a older one and i have to replace the front end anyways because it is all torn up, the rest of the body style is great. If so do I just replace the cover or do I have to replace the bumper underneath the cover? Or what?
Old May 2, 2001 | 11:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You would have to change just about everything (that bolts on), except the fenders and the impact bar and misc minor plastic parts
-Welders get better penetration
[This message has been edited by deadbird (edited September 27, 2001).]
Old May 3, 2001 | 07:17 PM
Keith5's Avatar
Car: C1500
I think the hoods are the same, every catalog lists for 82-92.
Old May 3, 2001 | 09:01 PM
firbird's Avatar
thanks a lot I am going to try it
Old May 4, 2001 | 01:04 AM
MrJ's Avatar
MrJ
why are you mutilating a car like this? You are taking a step backwards, going to the boxy Camaro-ish 80s style look. If you do decide to abominize your car then you'll need new ground effects for the front. And even then the square look of the front will clash badly with the smooth, aero look of the rest of the car.
Get another car and do it right.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old May 4, 2001 | 01:08 AM
deadbird's Avatar
Engine: TPI 305/ v6
Umm,,,it's a firebird,,, not a camaro,, and it's his car. He was only wanting to kow if it can be done (and the camaro nose never really changed dramatically either from 82 to 92)
(no flame intended)
Old May 4, 2001 | 07:10 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I have a similar question...
How hard would it be to get a 91-92 GTA front bolted onto my 86 TA? I think the 91-92 GTA front end is a hell of alot more aggressive, and if i can find the front end off one, i would put it on. Thoughts?
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old May 4, 2001 | 08:23 AM
cbpldc's Avatar
To whoever said that the body is different is wrong. Especially if it is a base or Formula firebird, because they don't have the ground effects. The best change would be to put the 88-90 Formula nose on there. That way, your front end won't be lower than the body (I'm referring to how the ground effects hang down). I suppose that if you wanted to put the '91-91 GTA nose on your car, I would get ahold of the same year ground effects. Otherwise, you will have a rounded front end on a squared off car (because of the GFX. The body parts themselves are the same).
Chris
Old May 4, 2001 | 09:01 AM
Pino91Formula's Avatar
the hoods , are all the same 82-92 and yes you would have to chane the bumbercover supports and all
Old May 4, 2001 | 01:07 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Hey Deadbird: Where'd ya get the illustrations? Is there a place online to look that stuff up along w/part #'s? I need a couple of those spacer/brackets.
1983 Firebird T-top- 383/TH350, South Side Machine SFC's & lift bars, 91 Formula bumpers, Harwood cowl hood, 89 T/A rear wing, 17" Centerlines, 89 Formula interior... Estimated completion date: never
Old May 4, 2001 | 01:22 PM
firbird's Avatar
i think at next generation f-bodies at
http://www.yearone.com/nextgenparts/...ages/main.html
Old May 4, 2001 | 03:50 PM
deadbird's Avatar
Engine: TPI 305/ v6
Link to the diagrams in my sig
Unfortunatly there's too many p/n's in the boof and I'm to lazy to put them to the pics (and since I'm pretty slow at typing/making web pages).
If you need a part # tho, feel free to ask or email me
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
