trunk needs adjustment
Old May 14, 2001 | 03:17 PM
gmussell's Avatar
The trunk(hatchback) on my 83 sticks out to far in the back, about 3/8 inch passed my fenders. Is there any adjustment so I can move it forward?
Old May 15, 2001 | 10:31 PM
Nightcruzer's Avatar
Car: Trans Am
Welcome to the boards. The answer you are looking for is detailed in one of the tech articles. Go to the opening page and click tech. Scroll down, you will find it.
Old May 17, 2001 | 10:25 PM
Duffster@Work's Avatar
Yes...yes he will find it
Very nicely written article I do believe
https://www.thirdgen.org/newdesign/t...tchalign.shtml
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Apr 20, 2006 | 05:53 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
If the link weren't dead. . .
Old Apr 20, 2006 | 06:17 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
loosen the 8 13mm nuts on the underside of the decklid. then use a long box cutter blade and cut the black glue till the decklid can be separated from the glass. take your time and have patience while doing this and you will be ready to go.
use black urethane windshield adhesive to seal it up when it is aligned the way you want it.
thanks
Old Apr 20, 2006 | 06:21 PM
Duffster's Avatar
My point to replying to this was getting a moderators attention. . .
because I wrote a tech article for this about. . .7 or 8 years ago.
Pictures and all. . .
Duff
Old Apr 20, 2006 | 06:54 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
i was able to ajust mine loosening the bolts on were the hatch connects to the roof when i took the arm things off but no matter how tight i cranked the nuts a few bumps with the arms reconnected pushed it back to where it was sticking out in the first place so removing the trunk peice is the be st way to go
Old Apr 20, 2006 | 10:55 PM
Duffster's Avatar
Try try again. . .
Maybe ya'll aren't understanding me and I thank you for attempting to help me!
I already know the FULL procedure and then some on this issue. I wrote a technical article for thirdgen.org about. . .7 years ago on this. Pictures and everything I know my sign-on date says something in 2000. I joined about 1998ish and guess there was some glitch. . . I'll get over it.
Point is, there is a technical article running around in the internet somewhere (hopefully in an archive for the board) that should be available for all at the link above. . .it ain't working.
Again, thank you for the advice, but not for me.
Duff
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
