Keyed!!!!!
Old May 23, 2001 | 10:51 PM
Rallyssport's Avatar
Keyed!!!!!
My 92 RS got keyed across the driver side door. I really dont have the money right now to have it painted...any sugesstions? Also some bitch nailed my driver side door right below the handle with a cart. I tried to hammer it back about but i think its creased...am i screwed? Let me know!
Old May 24, 2001 | 02:38 AM
86ZRICHIE's Avatar
some people deserve to be drug out in the street and shot...then moved to the curb so we don't scrape bottom on them
Old May 24, 2001 | 11:31 AM
jcyoung's Avatar
Rally, bad deal on the body damage. I have seen people air brush paint into a scratch. It is time consuming and the correct equipment is required, but a heck of a lot cheaper than a paint job. The scratch can not be to deep. Some of your friends might have the equipment if they are into hobbies. You would need to find touch-up paint and thin it inorder for it to work.
If you can find the paint in a can then you would mask off the scratched area and mist paint into the damaged area. You need to take your time and build the area back slowly.
On the door dent, try someone who does paintless dent repair. They use metal wands from the inside of the damaged panel to work out the metal. I had this done with great results on door dings I had. The dent can not be large, baseball size. Hope this helps
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
