Clearance between gas tank and cargo area floor pan?
Old Jan 31, 2013 | 09:20 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
Does anyone know how much of a gap is in between the cargo area floor pan and the gas tank? I am going to have a power distribution board for my amps in the cargo area and I need to be able to screw down my base to the car...but I don't want to run screws into my gas tank >.< any help will be appreciated!!
Old Jan 31, 2013 | 10:46 PM
toomany's Avatar
Re: Clearance between gas tank and cargo area floor pan?
I'd like to know as well, for other reasons though. If you are worried about running screws down into the tank, you could put a piece of wood under the cargo carpet. 1/2" or 3/4" should do ok.
Old Feb 1, 2013 | 04:37 AM
Engine: 305 4bbl
Axle/Gears: 3.08
That's exactly what I'm doing. I still have to fasten the wood to the chassis though. If nobody comes to our rescue by this evening I'll jack my car up when I get home from work and find out the hard way
Old Feb 1, 2013 | 07:27 AM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
The tank is up tight against the rear cargo pan. The only separation is whatever the insulation strip(or whatever it's called) on top provides. I'd be very careful about running screws through that area.
Old Feb 1, 2013 | 08:00 AM
Twin_Turbo's Avatar
This much:
Old Feb 1, 2013 | 08:04 AM
Engine: 305 4bbl
Axle/Gears: 3.08
Yeesh. Time for plan B. Thanks guys.
Old Feb 1, 2013 | 12:03 PM
toomany's Avatar
Rather than screwing the wood to the car, use a chemical bond. Get a tube of adhesive and glue it down. Some panel bond adhesive may work. Would have to check to see if it's compatible with wood. If not, than some from a home supply store should do.
Old Feb 1, 2013 | 12:11 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Originally Posted by Twin_Turbo
This much:
I have read it's less than an inch. I have installed many sound systems and I never screw the amp rack or anything to the body of the car. I have a nice amp board in my Camaro that the PO put in and it is not screwed to the car and does not move.
Old Feb 1, 2013 | 06:24 PM
Engine: 305 4bbl
Axle/Gears: 3.08
This is what I decided to do. Gonna check Vato Zone and Lowe's for the right stuff.
Old Feb 2, 2013 | 08:15 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Why not just velcro your amps to your carpet as thats what Ive done for years and its super clean looking with no wood added for wieght. Just my
Old Feb 2, 2013 | 07:31 PM
Engine: 305 4bbl
Axle/Gears: 3.08
I thought about that as well but I like to have something separating the power wires from the carpet...just in case. I did end up cutting my carpet out and using some epoxy to bond the wood to steel. When I get my new carpet I plan on carpeting around the fuses, distribution block, cap, and amp.
I did use velcro to secure my cap to the distribution board though as I couldn't find the mounting brackets that came with it.
Infested
May 22, 2018 11:56 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
AkDrifted
Aug 17, 2015 07:45 PM
