ac delete box same on all 3rd gens?
Old Feb 25, 2013 | 10:37 AM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
i have a non a/c box from a 84 z28, will that work in my 88 trans am? and does anyone know if the controls are the same, i realize the dashes are different, but i pulled the vents,blower,wiring and everything together, and id like to use them in the ta!! thanks in advance
Old Feb 25, 2013 | 11:28 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: ac delete box same on all 3rd gens?
All AC delete boxes are the same but the wiring for a AC delete box is different then a AC box. Did the 88 have ac in it? if so the AC delete box will still work but you will have to wire it using the existing harness which isnt too hard
Old Feb 25, 2013 | 12:55 PM
andy74's Avatar
the 88 had a/c but the previous owner took it out, i have the delete box from the 84, and the wiring blower etc from the 84.my question was if the controls are the same,because id like to swap out the digital non operational dash for a analog dash,with no a/c
Old Feb 25, 2013 | 01:16 PM
6SIX6's Avatar
Car: 89 IROC
I think you will need the non digital ones if the digital one doesnt work. Unless you can get the digital one to work then you can use the harness from the delete box insted of the old one
Old Feb 25, 2013 | 01:18 PM
andy74's Avatar
thanks! i am going to pull the digital dash and push button controls in th enext week or so, and see what is going on with them before i attempt to swap it all. i know i wont be putting a/c back in, so i ll check it out! thanks again
Old Feb 25, 2013 | 07:22 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm not sure how the push-button controls work, but you do NOT necessarily need to swap out the heater module (the thing containing the heater core) for a non-A/C one to use the non-A/C blower case. All you would need would be the control head and the vacuum harness for an A/C case. You can have A/C ducting without having A/C., and then you won't need to add extra vents and controls.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
