anyone ever have this problem
Old Mar 1, 2013 | 01:35 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
I never did before, or i just never noticed it. but at anything above 40 i hear what sounds like a wet hissing coming from: either behind the dash, or the passenger side window. Alot! of water leaks in from there and soaks the door panel. it has a new window sweep and a new triangle seal, like i said i have never had this problem before. i've never moved the door or messed with it, or the window triangle so idk if they could be miss-aligned or not. Any help is appreciated, ideas?
Old Mar 1, 2013 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: anyone ever have this problem
The underneath side of the door has holes which allow drainage. Could it be that those holes are blocked and the door is holding water?
JamesC
Old Mar 1, 2013 | 07:13 AM
MY1950COUPE's Avatar
Car: 1992 Z28 Convertible
Engine: 5.0
Transmission: auto
??? heater core ?? over on the right under dash could be leaking making the hissing,
Old Mar 1, 2013 | 08:54 PM
kmcn47's Avatar
Transmission: 5spd
if it was a heater core I'd have a puddle and smell antifreeze, i don't i ruled that out because the one in my bird went bad as i was driving and filled the car with smoke, i know what thats like, this isn't it. i dont think the doors are holding water the holes definitely aren't plugged. is it weird that my dash pad actually touches the plastic on the top of the door panel? because it doesn't on the drivers side. i'm gonna try and run with no door panel when it rains next to try and see where its coming in at.
Old Mar 9, 2013 | 07:31 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Is your moisture barrier still intact behind the door panel? Maybe the front of the door weatherstrip is deteriorating. You said you had a new window sweep, I'd check that moisture barrier, plastic liner behind door panel first. Maybe the wiring boot going into the door as water will follow the wires and can get everywhere.
Old Mar 9, 2013 | 07:33 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
mezmorized by your avitar. LOL very nice
Old Mar 9, 2013 | 07:49 PM
tomlyons's Avatar
Car: 92 camaro rs
Engine: 3.1
Axle/Gears: rear disc non abs
or you can email me tomlyons354@gmail.com i can walk you through it
Old Mar 9, 2013 | 08:27 PM
tomlyons's Avatar
Car: 92 camaro rs
Engine: 3.1
if you have the door panel off loosen the front window guide with door open roll up window and hand adjust the guide and tighten all the screws top first then the sides let the window do the alignment
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
