poping the hood problem
Old Jun 30, 2001 | 12:19 AM
92 z28's Avatar
hey guys, i have a situation that must be solved once and for all. well i know many of my fellow thirdgen buddies all have the same problem. everyone has a problem with poping their hood. after pulling the hood cable thing the hood doesnt pop up. you ussually have to play with it and try to get it to pop up. now i tried rasing the bumbers but that didnt help much. now if anyone knew what the solution is, or has any tips, i would appreciate it. thanks
dozer80464@aol.com
Old Jun 30, 2001 | 01:22 AM
Camaro_hunter_d's Avatar
well I have mangled the hold down hook on mine to get it to pop up... sometimes it get bent sideways and it has to be strightened.
Old Jun 30, 2001 | 10:11 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Hit the latch mechanism with a shot of grease on a regular basis... like at oil change time. Give the cable itself a smear of anti-seize compound where it runs into the sheath.
As for getting it open now, usually have somebody pull the handle and hold it, then you give the hood a few gentle pushes right above the latch - it should pop.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Jun 30, 2001 | 12:21 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Keep it greased well and you won't have any more problems out of it.
92 Camaro RS 5.0 5-Speed(Quasar Blue)
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jun 30, 2001 | 12:50 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
to get the hood to pop you have to push down above the latch and shimmy it side to side. I had this same problem and it was alingment related. if I ever had a problem I just pushed down over the latch and to the right and it would pop.
James
Old Jun 30, 2001 | 01:29 PM
Mark 89Formula's Avatar
Remove the striker from the hood, clean off the old grease and scale, relube with fresh grease, then bolt it back in place. As simple as it sounds, this solved the very same problem on my car.
Old Jun 30, 2001 | 01:32 PM
Tom Keliher's Avatar
I had the same problem, as has everyone else. I stretched the spring slightly. Solved my problem.
Old Jun 30, 2001 | 09:04 PM
CAMARORS1991's Avatar
Could this possibly have anything to do with the hood struts?? I have the same problem and I always thought it could have been the hood struts were not as strong as they used to be. Just wondering.
Old Jun 30, 2001 | 11:28 PM
age's Avatar
age
Car: 1992 Z28 1LE
I agree with cleaning and greasing the latch.
It's worked for me
But do you think that maybe getting a new cable would solve this problem?
Old Jul 1, 2001 | 09:07 PM
Chuck Everly's Avatar
Moving to “Body and Interior” board. You may get more help there.
Old Jul 1, 2001 | 10:32 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Do what i do with my 84 olds, pull the cable, then slam the drive side door and the hood should pop up.
Rob
Chevy 2.8L, k&n filter lid, Headers Soon!!!
Old Jul 2, 2001 | 12:34 AM
Rallyssport's Avatar
What I did was adjust the hook on you hood. It took some time you just have to play with it. Also put some new grease on the latch. Hopefully that works for ya!
Old Jul 2, 2001 | 01:50 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I had the same problem when I first bought my car. I just hosed the latch down with WD40 and then used some lithium lubricant on it. I haavn't had to touch it in 2 years. It pops the first time every time.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Bert87
Aug 23, 2015 03:50 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
