Door Swap Question
Old Mar 27, 2013 | 03:25 PM
DirtyBird87's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7L TPI
Door Swap Question
Hey guys. I've searched for an answer and found nothing so maybe one of you could answer it. Will a driver side door from an 82-92 Camaro fit on an 87 TA? Im trying to find people parting out Firebirds locally but Im having no luck. But there are plenty of people parting out Camaros. Thanks for the help.
Old Mar 27, 2013 | 03:28 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
Re: Door Swap Question
I have doors from an 86 camaro on my 83 TA because I wanted manual windows/locks/mirrors.
Old Mar 27, 2013 | 03:47 PM
Engine: 5.7L TPI
Thats great to hear. I want to retain the power functions though. Thanks for the advice.
Old Mar 27, 2013 | 04:34 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
They are both F Bodies are they not? Just make sure it has the appropriate addons (GFX kit, bumper trim, etc..)
Mirrors might be different, never really payed attention to the bird's mirrors.
Old Mar 27, 2013 | 06:34 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Everything is the same, period. Except some export cars got paddle mirrors.
Be warned that pre-85 cars have a different attachment for the front window tracks/triangle seals. You will need to retain the triangles/tracks if you end up changing anything inside the door (power to manual or the other way around). Found that out the hard way when I went to put doors from an 84 T/A on my 87 . The seals, however, will swap on the triangles, except for the later cars that don't have removable seals.
Old Mar 27, 2013 | 06:40 PM
Engine: 5.7L TPI
You sir are correct that they are both F-bodies. Now my next question is do I have to drill holes in a door from a non TA donor for the lower door piece?
Old Mar 27, 2013 | 06:43 PM
Engine: 5.7L TPI
Good info. Thanks guys.
Old Mar 27, 2013 | 06:48 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yes, you will need to drill the holes in a non-GFX door.
Old Apr 12, 2013 | 08:20 PM
Keoman's Avatar
So, how'd it go?
Old Apr 12, 2013 | 08:26 PM
Engine: 5.7L TPI
So, how'd it go?
Nothing yet. I've got a few offers from out of town but i'm trying to find one local.
Old Apr 12, 2013 | 10:09 PM
Keoman's Avatar
Yes, much better locally.
If you can, post up some pictures of any differences in the future.
Old Apr 13, 2013 | 07:18 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Just curious, why are you replacing the doors? Usually door replacement doesn't go well on these cars because of the welded on higes.
Old Apr 13, 2013 | 08:49 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Something I forgot and hasn't been mentioned. 82 to around 86 or 87, the door latches were held in with countersunk bolts. The later were held in with flat bolts. I believe the bolt pattern is the same but I personally wouldn't use countersunk bolts in doors that weren't made for them or vice versa. Too much stress on the metal.
Old Apr 15, 2013 | 01:26 PM
Engine: 5.7L TPI
Thanks for the info. Reason I want to do a door swap is because the previous owner did a horrible job trying to fix a dent. He just caked on bondo and drilled holes in the door that have started to rust in various spots. I feel like it would be easier to swap the door than to fix the damage he caused. Chime in guys if you know of any other routes I should take. I have little experience with body work but would like to tackle the job on my own.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
