A pillar molding?
Old Jul 18, 2001 | 04:01 PM
3gc's Avatar
3gc
Car: Z28
A pillar molding?
What's the correct way to remove and install the a pillar molding on a hardtop Camaro?
Old Jul 19, 2001 | 12:05 PM
3gc's Avatar
3gc
Car: Z28
Come on someone has to know how to take it off. I think I broke mine when I took it off so I want to know what the correct way is. And I have to take out those clips that hold the top part to the roof.
Old Jul 19, 2001 | 02:16 PM
MidnightZ's Avatar
I wouldn't mind knowing myself so I don't break mine while installing my guage pod. Is it really that difficult?
Old Jul 19, 2001 | 02:39 PM
Going Slow Sucks's Avatar
Almost every pannle you pull off will have some small damaged.The best thing to do is get all the screws out, and buy a clip remover and pry as close as you can to the clip's.If ya don't have a tool put your hand in behind the pannle and push/pull out.
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Jul 19, 2001 | 03:09 PM
TransAm4u2race's Avatar
Im a glass man so i know alot about interior panels. i dont know about our cars but check to make sure u have all the screws out and then just put presuure on it and pull
Old Jul 19, 2001 | 10:30 PM
3gc's Avatar
3gc
Car: Z28
There are no screws on the Hardtop cars. There's no room to remove the clips while the molding is still on. When I have to reinstall it I'm going to probably cut the little clips off of the roof and buy new ones and put it on that way. I just don't want to break it more the next time I have to take it off.
3rd Generation Camaros
Old Jul 20, 2001 | 06:44 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I'll take a guess here. I think you have to somehow slide them forward.
Old Jul 20, 2001 | 12:09 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Just pull it straight out. Pull towards the rear of the car. That's what I did and then it just slide right back in.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Jul 20, 2001 | 08:44 PM
Blue_Meanie86SC's Avatar
yeah, slide it toward the rear and pull down on the top part, then push forward and pull down on the front part. In theory it's simple, but good luck not breakin anything. oh, and it might be easier with the dash out.
Old Jul 21, 2001 | 04:42 PM
ian's Avatar
ian
Car: 83 berlinetta
Transmission: th 700
a trim fork is usefull I took the top roll off the dash because they can get wedged in.then gently pull to peek in to see the trim clips then use your fork to ease out while pulling the trim towards you aclip at a time
1992Z28!
Nov 19, 2015 07:33 AM
91 zeee
Interior Parts Wanted
Sep 24, 2015 03:09 PM
aharvel50
Sep 21, 2015 07:31 PM
Fox118
Sep 12, 2015 09:29 PM
