Door won't shut
Old Apr 21, 2013 | 05:39 PM
BftCamaro's Avatar
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
Door won't shut
Hey I previously just bought a 1987 305 auto z28 with t tops and the driver side door will not close. The hinges don't look damaged and the passenger door works just fine. When I shut it I can see the gap from the inside
Old Apr 21, 2013 | 05:48 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Door won't shut
The pic is too dark to see any real detail. Is the pin on the frame lined up correctly with the latch "throat"?
Old Apr 21, 2013 | 05:56 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
Re: Door won't shut
Yes
Old Apr 21, 2013 | 06:03 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: Door won't shut
pull and hold one of the handles and pull the latch toward the opening its half engaged it has 2 locking positions and its poorly alligned with the cut it in the door
Old Apr 21, 2013 | 09:59 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Door won't shut
Pic looks clearer now. It looks like the latch is pushed up and tilted and maybe the door metal is riding on the pin. Has the door sagged? Try putting some white electrical tape or some other marker on the latch and/or pin and close with the handle pulled up. This should show you where it's contacting. Also maybe remove the pin and close the door to see just how it's aligned without sitting on the pin. The pin shouldn't push the door up or down but just hold it tight in its natural position.
Old Apr 22, 2013 | 10:11 AM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
Re: Door won't shut
Here's some more pictures
Old Apr 22, 2013 | 10:12 AM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
Re: Door won't shut
Here's the striker bolt
Old Apr 22, 2013 | 01:37 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Door won't shut
The groove in the striker bolt really makes it look like it's the door metal that's riding on it and not the latch guide. Take the bolt off and see where the door sits. That needs to be correct first. You may need to replace the door hinge pins or re-adjust the door before trying to get the latch lined up right.
Matt86IROC
Sep 7, 2015 06:30 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
