How to attack a golf club dent...
Old May 5, 2013 | 09:04 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
So 3 days ago a random person decided to smack my hood with a golf club. I might have a shop fix it if it isn't worth the effort ($250 for insurance deductible). How difficult would this be to diy fix? There is a hood support directly behind it but could I pop this type of dent back out clean? Would it be plausible to touch up the paint with rattle can factory match paint and clear?
Thanks for any input, here's the damage
Old May 5, 2013 | 09:19 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: How to attack a golf club dent...
WTF!??!
Don't know what it'll cost, probably use a " stud welder " or whatever its called--
Weld some " studs " in the dent & pull out with slide hammer, grind off the studs,
fill, smooth, paint.
Old May 5, 2013 | 10:47 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
research the dry ice method.
Old May 5, 2013 | 10:49 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
I will agree that a stud welder and slide hammer can fix this, You can get a cheep stud welder at harbor freight real cheap, when doing this start on the outer edge of the dent and work your way around to the middle, use light pulls slowly working the dent out.
Old May 6, 2013 | 05:00 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Metal is stretched already. You'll need to shrink that or have a large high spot to try and repair. Stud gun should have a heat tip with it to help shrink it. Shrinking hammer might work if you could get behind it.
Old May 6, 2013 | 10:16 AM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Thanks for the suggestions. If a stug gun is the best way to get it done right I might have a shop do it since I have no experience doing that. I got an estimate for 300 to fix and paint the whole hood from a good shop.
Old May 6, 2013 | 11:03 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
A body guy I know told me that he sometimes removes small hood dents by heating them and dropping ice on them. Supposedly that shrinks the metal back into shape. I've never tried it myself.
Old May 6, 2013 | 11:28 AM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
ok maybe I'll try that if i can find dry ice. I don't think it could hurt since the paints already gone. That would be very "cool" if it worked.
Old May 6, 2013 | 02:30 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I got $2 dry ice from walmart and tried it out a few times. It did well... something. But nowhere near fixed. Interesting idea though.
Old May 6, 2013 | 02:42 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Who takes a golf club to a mans car. Thats just wrong. I hope you get it fixed soon
Old May 6, 2013 | 02:49 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I agree!
I'd be interested in seeing the before and after results with the dry ice trick. I've heard about it and wondered how it would work on some small hail dents I have.
I'd also be interested in hearing the "tiger woods" story too.
Old May 6, 2013 | 08:30 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
For $250, I would let a shop repair it. Thats a nasty dent. You probably have the hood liner in it, but the back side is (probably) damged as well. As Whitegold88 stated, some shrinking is in order.
Old May 6, 2013 | 08:35 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
I cant help with the dent but I would take the gold club to hit damn face if that was my car.
Old May 7, 2013 | 04:14 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
thanks for the sympathy haha, but here's what it looks like after dry ice. Not totally sure if its different but I think just a bit.
Old May 8, 2013 | 09:51 AM
1Aauto's Avatar
Former Sponsor
Man....that caused some damage. Who the heck does that sorta thing.
Old May 9, 2013 | 02:20 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Dry ice ruins the metal. On hot summer days it will show the dent through the paint even after it's repaired if you fatigued it with dry ice.
Personally, I'd probably get a used hood and have it resprayed but if you really want to fix it just pay the shop. A minimum, it needs to be pulled, hammered, filled, sanded and painted.
-- Joe
88CamZ
Oct 8, 2015 10:29 AM
buckeyecelt
Sep 24, 2015 05:50 AM
anesthes
Sep 18, 2015 12:34 PM
ronchic
Mid-Atlantic Region
Sep 10, 2015 02:32 AM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
