Half of the speedo lights are out!
Old Jul 31, 2001 | 09:17 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
On a trip to Talahassee today the left haft of my speedo went dim. This has been happening for about a month now but usually if I just give it a good tap or two it lights back up. But this time it didn't. From 110 to 80 it's as bright as it's ever been but from there down it gradually dims into no light at all. Before I could get home the needle wasn't lit either. What could be the problem? Is there just a light burnt out in there or a bad connection or what? Also everytime I get in the car it takes about 5 minutes for the air conditioner to start working and I've never had a problem with it either. If I put the pedal to the floor the ac will come to life. Who know what my problem could be?
91 Camaro RS - Black with red tweed - t-tops - 700 watt sound system - 14x3 open element - 80 Series Flowmaster - muffler turndowns - Poly transmission mount - Future 12 second street car
88 TransAm GTA - WS6 - red with grey cloth - K&N Filters - TPIS Airfoil - Wonder Bar - Future Restoration
Old Jul 31, 2001 | 09:27 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm not A/C guy,, but you need to change the bulbs.
(I almost started to explain why the bulbs do that but decided not to bore you to death )
The mind is like a parachute, it only works when its open
Old Jul 31, 2001 | 11:00 PM
maksik7's Avatar
The bulbs are difinetely burned out and need to be replaced. Had same prob in both my cars when just bought them.
About the AC, isn't that noraml for it to have to warm up a bit before giving out really cold air. Also if you up the rpms the belt spins the compressor faster and thats prolly why your AC comes to life when you jam the gas. I could be wrong on this since I took out my AC as soon as I got the car
-Max
86 Trans Am LB9/700R4
-Flowmaster 3inch exhaust, K&N, Ported Plenum, Redone Ignition system
Old Aug 1, 2001 | 12:54 PM
Ok, does anybody know which light I need? Is there a part number or anything? And the ac wont work at all for a few minutes or until I floor it. I guess I'll go get it check out unless I can figure it out on my own. Anybody else got any help for me?
Old Aug 4, 2001 | 09:39 AM
slowmaro92305's Avatar
bulbs are "194"'s, i believe
Old Aug 5, 2001 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I would advise you to replace the bulbs in your cluster with xenon bulbs from McEwen (I prefer the clear type, but colored are available). They're much brighter.
JamesC
Ghettobird52
Jul 5, 2024 11:18 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Omega
Aug 10, 2015 12:46 PM
