Can't find a kit that includes this hinge piece, don't know what to call it
Old May 22, 2013 | 02:45 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
The doors on my '88 Trans Am are in decent shape, and I've already replaced the lower hinge pin. But the pin that hold the bracket that the spring connects to is loose and looks like it could come out. This isn't my pic, but it shows what I'm talking about -- it's the pin closest the camera. I've been trying to find a kit that has a replacement, but no luck.
Also, while I was searching, I came across references to a GM spring tool for about $12. Does any1 have a link?
Old May 23, 2013 | 05:11 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Can't find a kit that includes this hinge piece, don't know what to call it
Not sure what to call it either but one way you could repair that is to remove the spring/pressure from it then get it sitting flat again and weld it from the bottom. I haven't seen them available seperately either. The only way I've seen them is with the hinge which is expensive. Good luck with it and let us know how you repair it.
Old May 23, 2013 | 07:37 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Subscribed
My Camaro door looks exactly the same, getting ready to swap it w/ new door, need to find hinge kits (pins and bushings)
Old May 23, 2013 | 10:37 AM
L-Train8's Avatar
Car: 1990 Trans Am GTA
I think that pin is called a detent pin. Top Down Solutions has a pretty complete selection of hinge replacement parts. They have a detent pin and roller, and also sell the GM a spring tool. I just ordered a bunch of stuff from them to fix my door. Two weeks after I bought my dream car, a 1990 Trans Am GTA, my wife backed out of the driveway and scraped the passenger side door with our minivan. The dent is pretty minor, but it tweaked the door enough that it won't close right and the alignment is all messed up. Hoping some new hinges and some work with the alignment will fix the problem.
http://www.top-downsolutions.com/Bod...y-and-Interior
Old May 23, 2013 | 12:19 PM
89RAG's Avatar
Car: 89 IROC-Z CONVERTIBLE
Engine: 5.0L TPI
its called a door check. bolts on the inside of the door. stops the door from opening into the fender under windy conditions.
Old May 23, 2013 | 04:30 PM
L-Train8's Avatar
Here's a great article, with lots of pictures, on replacing door hinges on third gens.
http://www.highperformancepontiac.co..._aid_part_iii/
Old May 23, 2013 | 10:39 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
haha thats my picture! never did get around to fixing it though I should get on that. If you find the pin let us know
Old May 29, 2013 | 01:10 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
No, the detent pin and roller is in the back of the pic. I'm talking about the pin in the foreground, that holds the detent bracket to the door side of the hinge. I searched that site, but I still can't find the pin I'm looking for. I did see the spring tool, which is unfortunately what I already have. I was hoping for something better, as it's pretty tough to work w/ that tool given the tight space around the hinge.
Yeah but removing the doors and replacing the entire hinge seems excessive just to replace 1 pin! I can't believe w/ all the hinge repair kits available, none of them seem to have this piece
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
