Got A/C Done - Did I Get Ripped Off
Old Aug 15, 2001 | 08:30 PM
Tyler-88's Avatar
a guy today recharged ym R12, he charged my $80. is this a good deal or no to have cool air? what have you guys payed?
Old Aug 15, 2001 | 08:38 PM
Z28DJP1987's Avatar
Not bad, how much r-12 did he use and is it pushing cool air now?
Old Aug 15, 2001 | 10:22 PM
Tyler-88's Avatar
not sure how much he put in, but i think i had like 0psi in there so prolly like 3/4lbs and its not ice cold, but it works good. he said my a/c pump is only working at 70% but it'll do for the year.
Old Aug 15, 2001 | 11:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Freon is $20 some-odd a can this year and a full charge is more than 4 cans, so you did OK. At least you didn't get ripped off.
ICON Motorsports
Old Aug 16, 2001 | 09:44 PM
Russ-So Cal's Avatar
At the shop where I work, our price for r12 is $63.50/lb. We don't carry anything except 30 lb disposable cans. Needless to say, I don't carry R12 on my service truck, and I convert a lot of systems to drop ins like 409a.
Old Aug 17, 2001 | 06:51 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
R12 is rare and hard to find. You should have paid substantially more if your system needed more than a pound or so. If you're more than about 2 lbs low, it's cheaper to switch the system to 134a.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 17, 2001 | 01:28 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Thats VERY reasonable
John
Old Aug 17, 2001 | 03:19 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
That does sound good, but it is leaking somewhere. Freon should never go bad, or you should never loose it, unless you have a leak somewhere. Usualy the seals around the compressor get dry and crack. But $80 is good even if it only lasts a year.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Soon to have:
350, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, T&R Motorsports custom air intake
Old Aug 17, 2001 | 09:50 PM
Actually the most common source of leaks in the a/c system is not running the system in winter, and not using the defroster in the winter (defroster turns on compressor clutch). The seal in the compressor is actually a thin film of oil between a polished steel surface and a polished carbon seal. When the compressor runs the oil pump keeps the seal lubricated. When it sits without operating for weeks, the oil runs off the seal, the freon seeps out. You start the engine and turn on the air, the clutch engages until the low press cutout turns it off, the pump reoils the seal, and there is no sign of a leak. Unfortunately you have shut the proverbial barn door after the horses or in this case freon has left.
Veaceonee
Sep 29, 2016 08:15 PM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
