Saving his Precious Pink Camaro
Old Jun 11, 2013 | 08:18 PM
Guardian452.BOB's Avatar
my stepdad has a 84 with a very very tired v6 and various mechanical / cosmetic issue lack of interior liners and covers radio doesn't work ... the list goes on and on ...
recently the Transmission cross member pulled the bolts out because the unibody has the consistency of shredded wet paper towels
after some fiddling and metal submission therapy he welded some 1/16 steel and rebuilt the portion of the unibody that the cross-member attached to
the rest of the car is worse/no better so my question is thus: what are the Options here buying a new car is out of the question mainly because it was a tribute to his children that he lost in a fire
as far as I can see the only way to save it would be the pull the car down to nothing and start re-welding and re-fabricating the majority of the car
I been looking for a weld-in under-frame or braces but all I have found is subframe connectors witch do me no good because there is literally no subframe left
Old Jun 12, 2013 | 01:17 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Saving his Precious Pink Camaro
You could always look for a donor car and strip it of the subframe pieces you need to redo or you can make your own out of box tubing or anything else you can think of to work. pretty much all there is , is subframe connectors and thats it
jklein337
Sep 19, 2018 06:23 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
penguinpanda0
Aug 15, 2015 06:45 PM
Polo Z03
Aug 14, 2015 10:49 AM
ZsTransAm
Aug 11, 2015 07:30 PM
