how much paint to use for the car??
Old Jun 14, 2013 | 09:12 PM
ealyboy2013's Avatar
Car: 1987 Trans Am
Engine: carb. chevy 350
Transmission: 5spd
Hey so i'm gonna be painting my 87 trans am here in a month or two after the prep work is done, its gonna be done in Candy Apple Red, and I'm just wondering how much paint to use for the whole thing? in paint-able quarts... just in general, how much would you use? I'm having a friend paint it who is a professional painter, and he'll probably know how much to get, I'm just trying to get an idea so I know how much it's gonna cost for materials haha
Old Jun 14, 2013 | 10:51 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: how much paint to use for the car??
It depends on the color and the brand. I've sprayed Dupont's waterborne paint line which covers in one coat then a light mist coat immediately after. PPG's waterborne ususally covers in 2 coats and a mist coat. I sprayed my brother's saturn with Omni and that took 3 coats. When I painted my Alero with Shopline paint it took 4 coats... So its hard to say. If your painter friend is a professional he should be able to give you a rough idea
Old Jun 15, 2013 | 02:57 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Candy Apple Red sounds nice. I cant wait to see it .
Old Jul 29, 2013 | 07:42 PM
Car: 1987 Trans Am
Transmission: 5spd
Hey thanks for the input guys, I've heard from another thread that they used about 2 or 3 quarts for each layer (primer, base, clear) is that somewhat accurate?? they were all using different brands soooo... ???
Old Jul 29, 2013 | 07:58 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
If you think it'll take 3qts, buy 4 qts. Its better to have more than you need, than try to get more mixed and have it match. The 2nd batch hardy ever matches the first batch. It's better to spend the extra 60-90 bucks than repaint the whole car, if you run out of the first batch and the 2nd not match.
Old Jul 29, 2013 | 08:10 PM
Engine: TBI,5.0
Thankfully I had some paint left over because it was a custom mix.
A shop crushed one of the ground effects because they did not know where to put the arm of the 2 post lift.
The body shop used some of the paint I have and you can't tell it was ever wrecked.
Definitely have some paint left over.
Old Jul 31, 2013 | 01:54 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Both cars
Old Jul 31, 2013 | 01:55 PM
Both cars I've painted need 5 or 6 quarts. We aren't professional painters but that it what we went through.
Old Jul 31, 2013 | 02:10 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
I painted my engine bay with a quart, and used every last drop. That is two coats with decent coverage. I used PPG Envirobase.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
