Droopy Visors
Old Aug 28, 2001 | 10:20 PM
86Z28TPI's Avatar
Droopy Visors
Hey Guys,
I searched the entire sight and couldn't find anything on this. My visors droop down as I drive! Every bump or rattle they get lower and lower. If I hit a bad one on the highway they both go all the way down!!! Any ideas on how to tighten these Damn things up? It's a T-Top car. Thanks everyone!
Old Aug 28, 2001 | 11:22 PM
blackZ28's Avatar
i got the same damn problem...im thinkin about just gettin new ones.
Old Aug 28, 2001 | 11:46 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Okay guys, I had the same problem with my driver's side visor. First I had them recovered when I had my T Top headliner redone. Then I bought some velcro. Instead of using the glue that comes with the velcro I used Superglue on each piece. Works perfect and you can't see it when the visor is up. When the visor is down, since the headliner is black and the velcro is black, can't see them then either. Velcro and super glue, cheaper than new ones.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
[This message has been edited by 86NiteRider (edited August 28, 2001).]
Old Aug 29, 2001 | 07:36 PM
86Z28TPI's Avatar
Thanks guys!
Old Aug 30, 2001 | 12:13 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I have the problem as well and just haven't gotten around to it, but was gonna do the velcro and super glue idea.
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
Old Aug 30, 2001 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I experienced the same problem. I finally discovered that the visor itself wasn't the problem, but rather the hanger. The bullet-shaped rod that inserts into the visor had broken free and as a consequence swiveled on the hanger, which meant that regardless of how tight the visor was secured to the rod, the visor drooped. Junkyard hangers for next to nothing and the fix was in place.
JamesC
Old Aug 30, 2001 | 06:48 AM
Project86Iroc's Avatar
I also had this problem on every Camaro Ive owned. My solution was the hanger also. Remove the visor from the car. you should see a phillips head screw in the visor itself near the hanger. remove it and carefully pull the hanger out of the sunvisor(you may have to twist while you pull) There is a bushing inside the visor that you cannot access without tearing the visor apart, so go to plan B, switch the drivers side hanger with the passenger side. This way the worn out side is now the roof side, an angle of motion the visor wills= seldom see
Mike
1992 Trans Am
May 10, 2023 07:19 PM
PurelyPMD
May 5, 2016 04:57 PM
KAOSRacing
Apr 23, 2003 02:56 PM
TZFBird
May 18, 2002 10:47 PM
SgtSkip
May 1, 2002 06:38 AM
