Can I start wet sanding and buffing?
Old Aug 14, 2013 | 07:23 AM
Albani's Avatar
Car: 87 GTA
Transmission: Automatic
Axle/Gears: 2:73
The paint I used was not automotive. From WalMart - Krylon acrylic latex enamel, gloss black. The car was sprayed. Lots of runs. Sanded down the runs and re-primered. Sanded 1200 grit then repainted using roller this time. Did 7 coats, waiting 2 hours between coats. It's been 2 weeks and paint not dry (I don't think). Touch it for a second, pull back, it's sticky. Touch it and hold for 5 seconds, pull back, it's sticky and leaves a fine print. Should I start with my wet sanding?
Old Aug 14, 2013 | 08:06 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Can I start wet sanding and buffing?
Good luck with that mess. Watch how fast fine sandpaper gums up with partially cured paint.
Is this even doable? I doubt that type of paint is meant to be sanded smooth.
I think you ruined a TA.
Old Aug 14, 2013 | 08:20 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
You can start by stripping all that garbage off the car and doing it correctly.
Old Aug 14, 2013 | 10:25 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
LATEX?????
Really?
On a car?
Sometimes, when the paint and bodywork is really fubar, there is only one way out.
Old Aug 14, 2013 | 03:23 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Dude..... Doing it right isn't that expensive.... Why would you cut corners?...
If it hasn't hardened in 2 weeks it probably won't. Strip it and try it again. You can get a half way decent gun at Harbor Freight for like 15 bucks, get some paint mixed at Napa, hang some tarps in your garage & do it right...
Old Aug 14, 2013 | 04:04 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
"Good judgement comes from experience and experience comes from bad judgement."
You always have choices. Either live with a sticky dull paint job or start stripping it and doing it right.
Old Aug 14, 2013 | 04:29 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Ummmm no my friend dont try it. You need to strip that paint off. Do as suggested get a gun and have some paint mixed. If its still not cured and sticky imagine what it will be like driving it a few days with dust and bugs. You'll end up having a bigger mess to fix. Take your time don't rush it make sure you get all that paint off and start fresh. No matter what you spend on a paint job if its not prepped correctly it will still look like crap.
Old Aug 26, 2013 | 05:13 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
At this point, you only have 2 options:
1) Start over. And just getting back to the original paint will not be possible.
2) Do nothing, because in time, weathering will cause the Krylon to fade
and run. (Go ahead, ask me how I know this. )
At which point, see #1 above.
PS. Enamel is not made for color sanding.
Old Aug 26, 2013 | 06:00 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Please....enlighten us.
Old Aug 29, 2013 | 07:43 AM
Albani's Avatar
Car: 87 GTA
Axle/Gears: 2:73
Update - Paint dried, I wet sanded, buffed, polished, and waxed.
Results - Did not shine up. Has a little shine, looks like satin black.
Looks great from 15 feet, not so good up close. At least it's smooth as hell, and should last if I keep waxing. Yeah, it will need to be redone, but I'm tired of messing with it. I can live with it for now.
I've learned my lesson everyone, don't ever use cheap Walmart enamel paint. EVER!
Old Sep 2, 2013 | 03:16 PM
Albani's Avatar
Car: 87 GTA
Axle/Gears: 2:73
Here are pictures of the end results...
Old Sep 2, 2013 | 06:16 PM
stealtht/a's Avatar
Yup, that's looks terrible. Hope you have better luck on the next try.
BTW, the kink in the hood and completely misaligned hatch don't help.
Old Sep 3, 2013 | 08:22 AM
Richboll's Avatar
Engine: 305 TBI
I have seen worse, but it does make a Maaco paint job look really good. At least it's all one color. That's always a plus.
Old Sep 3, 2013 | 09:30 AM
Joe Tag's Avatar
Sometimes I see threads here and all I can do is sit back and shake my head. If you don't have the time or money to do it right, do you have it to do it again? Latex? Really? Even a rattle can job has much better odds of coming out passable from 20 ft.
Old Sep 3, 2013 | 09:49 AM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
D@mn, don't even know what to say....
Old Sep 3, 2013 | 01:44 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I would try to clear a small area and see if it shines up.
Old Sep 3, 2013 | 02:26 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Your big mistake was using latex, nothing wrong with a roll on paint job if you use the right paint. In the future when you want a proper repaint a shop will probably charge double.
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
fasteddi
Sep 2, 2015 10:29 AM
92camaroJoe
Aug 13, 2015 06:07 AM
