Ground Effects
Ground Effects
I am not sure what ya'all think of ground effects, but I am curious as to how good/bad my '91 Camaro would look with out them. If any has pictures of some camaro's with out ground effects, please post or link! thanks!
terrible. Trust me. They should have just designed the bottom the way gfx make it look. Otherwise it looks goofy, all the edges curve under and the nose getts really f*up looking, it makes itlook like its 5 ft off the ground.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Here's my terribly goofy looking 84
http://www.deadbird.org/b/tire-.jpg
Granted the car itself is a p.o.s. but, I prefer it w/o fx, I wish it didn't look 5ft off the ground though.
I wouldn't suggest taking off the gfx if you have them though unless you feel like filling holes & puting on a new front bumper.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 29, 2001).]
[This message has been edited by deadbird (edited September 30, 2001).]
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
Deadbird, I actually LIKE the way yer camaro looks, you can actually see some of the camaros classic lines with out the ground effects. Any way, when i repaint mine, i'll find out fer sure if I like no grnd fx...thanks fer the replies
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I actually prefer Firebirds without the GFX & the Camaros with the GFX. I like single color cars generally, but there are some multi color cars I have seen I like. Blue over gray for example.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
G O D BLESS AMERICA
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
I like mine without the ground FX, it's a stock SC. I don't have a pic, but I have noticed that if you take the FX off of a Z-28, it seems to have a different nose than the stock ones. The under-chin air dam on stock ones may not be on yours, right in front of the tires.
I do know that without the FX, the car is lighter and has better aerodynamics. One wouldn't think so, but Chevy did tests or something....
The reason I like it without is mainly because everyone else has 'em...to find a stock Camaro that isn't beaten up (or V-6) is rare around here...
i think it looks just as good as one with ground effects, it does make you car look higher off the ground though, here are a few pics of my baby:
i know you cant really see the bottom of my car but in the second pic, right under the red strip would be where the GFX start, i love my SC GFX or not, it's just your tast.
as long as it's a Camaro and looks tight, its all the same
87 V6 2.8 MPFI Camaro SC
Modded dual snorkle intake "bottoms hacked off", K&N air filters, Crane Cams 8.5mm fire wire, Accel Cap and Rotor, MSDcoil. upcoming mods:
Dynomax CatBack exaust system = VERY SOON
crane cams camp shaft, CC roller rockers, double timing chain
[This message has been edited by 87_Camaro (edited October 04, 2001).]
Car: 91 RS
Engine: 350 H.O.
I think they look gross without the ground effects, especially on one that originally had ground effects, i agree though that firebirds look good without them, cause the front end is so different
I think that you should leave the gfx on there they look to high without em, unless you lower it. I have never seen a camaro without gfx that was lowered, might look good..
87' Camaro Z28
305 TPI
Stage 2 hypertech chip
160 degree thermostat
Custom ram air w/K&N's
air foil
shift kit
aluminum driveshaft
posi
VST gas ryder gas shocks
3" flowmasters
Vortex cherry bomb high flow muffler
87' Camaro Z28
305 TPI
air foil
shift kit
aluminum driveshaft
posi
3" flowmasters
here is a link to my website www.geocities.com/carsnjunk cick on My 86 camaro and you will see my 86 sport coupe that has been lowered with the eibach pro kit I think I took the picture not to long after I lowered it so the springs have settled a little more now.
Damon
Sep 26, 2015 04:29 PM
