Anyone have a pic of hatch motor?
Old Oct 4, 2001 | 10:15 PM
Vomex's Avatar
I was wondering if anyone had a GOOD pic of the rear hatch motor while it is in the car. I just took a look at mine for the first time and it is a mess. The clear plastic housing is cracked all over so the previous owner decided to zip tie the crap out of it. And there is a loose connecter that i dont know where it should go. It is white and four wires go into it, i think they were red white green and black. Anyway if anyone has a pic it might help me get this thing working. Thanks
Later,
Vomex
'89 GTA 5.7L TPI
Old Oct 5, 2001 | 12:20 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'll see about getting you a picture.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 9, 2001 | 09:36 AM
lonsal's Avatar
I e-mailed you a picture of it installed. Verify those colors in the white connector. Mine are black, white, orange, brown. That connector comes from the latch portion of the pull-down assy and plugs into a black molded piece connected to the motor. The only wires going to the pull-down assy are a red with white stripe (constant hot) and a black wire that goes to the hatch release solenoid. There is another black wire coming from the relay that goes to ground. Some models have two ground wires. The second one is for the rear compartment light. Let me know if you need more info to get this working on your car. The clear plastic housing is available from GM. It should be reinforced at the screw mounting locations. I've used thin aluminum strips eposied around each screw mount to reinforce them. Once you have the motor housing apart check the gear nut. It is also available from GM. I make replacement plastic guides if you need those. Good luck, Lon.
Old Oct 9, 2001 | 10:46 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Some one put a pic on my forum. Look at the hatch pi$$!ng me off Forum. That the problem with my hatch. The plastic is cracked on mine too. What I did is put a bolt & nut throught the brace holding the plastic piece on.
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Old Oct 9, 2001 | 11:29 AM
FiReBReTHa's Avatar
hey buddies, what if i told you they finally started reproducing those pieces,
i think www.thirdgenresource.com has them
25$ !!!!!!
|--| (smilie rock on)
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 9, 2001 | 12:13 PM
Good deal, the whole assembaly for $75.00.
>I just needs two plastic pieces to fit in the rails and some time to mess with it. Do ya that they would have just those two pieces?
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Old Oct 9, 2001 | 01:06 PM
30 bucks for that plastic piece dude.
http://www2.theworldataclick.com/000...ppingCartID=62
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Old Oct 9, 2001 | 07:29 PM
lonsal's Avatar
FYI, the '92 plastic motor housing piece is different. That one is correct for 86-91 only. The 92 has a motor housing with two flat sides on it. By comparison 86-91 motors have a round housing. They are not interchangeable. I am going to e-mail them to correct their description of the part.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
