I drive a 1991 GTA which has a decent amount of interior lights. I was wondering if all third gen birds shared my lighting options and if the Camaros did too.
Basically, I have the lighted rear view mirror which has driver/passenger reading lights. It also has a small light that shines down onto my center console which is always on when the headlights are on.
I also have a little amber colored light that is above my HVAC controls. Bascially, it shines down towards the HVAC controls and ash tray area.
So, what other F-bods have these lighting schemes?
I have lights near the kick panels in the front, the 2 map lights on the mirror, one dome light, one light that shines on the dimmer switch and headlight switch, and the light over the hvac controls.
I want to add some lights in the back seat area so that I can see back there when it's dark.
WS6 Trans Am.
View My Ride @ thirdgen.org
WS6 Trans Am.
Ok let me think here. I have the mirror lights, and the light for the headlight switch. There is also a set of lights in both of my rear sailpanels. This is a convertible though. The lights in the back seat are just below the little armrests. They have the same lenses as the trunk light.
If I remember correctly this is the same as the light that was in my 92RS in the cargo area. These put out a lot of light. They light up the whole interior when they are on. They only come on when the round switch is turned on. They stay off if I turn on the mirror lights. I'm also assuming they use the same bulbs as the cargo area lights.
Apone, what light are you talking about that shines on your center console when the headlights are on??
??Member
All I have is the top light on the t bar and a light by each door.
1984 Z28 Camaro
Mods: 350 ci built by Ultimate Performance Inc, 4 bbl Quadrajet rebuilt by Holley, 700R4 Rebuilt by Level 10, Hyptertech chip Stage 2, K+N air filter, Edelbrock TES exhaust manifold, Flowmaster Muffler, 3.73 Richmond gears, Auburn Posi Limited Slip Differential, KYB Shocks and Struts, Edelbrock Panhard Bar, Trailing Arms, and Strut Tower Brace, TRW Springs, 245/50/R16 Embassy Tires(Yeah, I have no more money.)
Future Mods: Paint!
1984 Z28 Camaro
Future Mods: Paint!
I've got one at each kick panel, two on the overhead console (dome light & map light). I bought a 4th-gen mirror with the reading lamps to lighten it up a bit. If I ever get around to it I was going to cut little notches in the door panel near the back so I have lights for the rear seats... I'd probably use a lense similar to the one in the hatch area.
1986 Camaro IROC-Z
Code 23 Paint ("IROC Blue")
305 TPI
B&M Megashifter
ZZ4 Engine Swap Planned
1967 Camaro SS-396 (Dad's)
Former drag car
Original paint
11,000 summer miles
View my website, a work-in-progress
1986 Camaro IROC-Z
305 TPI
B&M Megashifter
Former drag car
Original paint
11,000 summer miles
On my 84 TA (which I just finished the entire interior) there is one light by each kick panel, a dome light.
NON courtesy: rear hatch area light (goes on when hatch is open or can be switched on), light for shifter position, 2 map lights L&R, AC light, ash tray light and glove box light. Plus of course all the dash lights and the rear defroster switch has a light that goes on when pressed.
Non stock: lighted cigarette lighter
[This message has been edited by Nightcruzer (edited October 11, 2001).]
Mine only came with a dome light, map lights, and a ashtray light that is mounted next to the map lights in the rear view mirror.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
Jim 86 Bird, I believe he is talking about the 3rd light that is on the bottom of the rearview mirror. My 91 Firebird has it too also the bulb inside recently burnt. It's a looks like a little slot on the bottom of the mirror towards the inner passenger's side and projects light down onto the center console.
