1982 Indy Pace Car Emblems and Hatch
Old Sep 4, 2013 | 01:26 PM
MACZILLA23's Avatar
I have an 1982 Pace Car that im trying to restore. Can somebody confirm or post pics of the original emblems on the exterior of the car. I would appreciate that!
Also my hatch seems like there is something missing or its different. At the top it shows metal where the hatch opens and closes at the top. Is that the norm? I thought that it was just the 2 black rubber pieces.
Attached Thumbnails 1982 Indy Pace Car Emblems and Hatch-c.jpg   1982 Indy Pace Car Emblems and Hatch-ce.jpg
Old Sep 4, 2013 | 05:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1982 Indy Pace Car Emblems and Hatch
http://www.phoenixgraphix.com/gm/1982pc.php
Old Sep 4, 2013 | 05:46 PM
MACZILLA23's Avatar
Originally Posted by mantaguy
I know those decals. Im actually talking about the Z28 emblems and such. Which exact ones they are. Thanks though
Old Sep 4, 2013 | 07:12 PM
mantaguy's Avatar
Engine: 5.0 EFI
If it's a Pace Car,that's what it should have!,here's another set for the 82-84s
http://www.phoenixgraphix.com/gm/8284z.php
Old Sep 4, 2013 | 07:18 PM
MACZILLA23's Avatar
That kit and the pace car kit dont inclue the hood ornament, Z28 emblems on the ground effects on the sides and the Z28 Trunk emblem. Those are what im talking about.
Old Sep 4, 2013 | 07:34 PM
mantaguy's Avatar
Engine: 5.0 EFI
Maybe you should check out Phoenix Graphics,they probably have what your looking for.
Old Sep 4, 2013 | 07:51 PM
MACZILLA23's Avatar
They do not carry the emblems from what I understand. Ive looked before and just look again. Im not sure they are different from the other Z28's. I just want to make sure if they are or not and what exact color they are.
Old Sep 4, 2013 | 07:56 PM
mantaguy's Avatar
Engine: 5.0 EFI
Give them a call,800-941-4550,they'll answer your questions.
Old Sep 6, 2013 | 03:36 PM
MACZILLA23's Avatar
Any help with the hatch is much appreciated!
Old Sep 7, 2013 | 01:45 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Your hatch is off a later model camaro that had the hatch mounted
brakelight. That one has been removed.
So I can guess your hatch glass has been replaced at some point.
Old Sep 7, 2013 | 10:29 PM
MACZILLA23's Avatar
Ok so the 82's didnt have the rear brake light option? So to make it back to original ish form i need to find an 82 to ?? year to match what was originally on there.
I appreciate the help!
Old Sep 8, 2013 | 10:13 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
YUP...........That third brake light deal was started in 85? or 86? cars.
Later they put it down in the spoiler. You can't remove the mount
from the window because there is 2 holes in the glass.
You could swap the glass BUT the tail and spoiler along with the glass is bonded into one piece. They can be separated but it is a
nightmare to seperate them! If you find a earlier glass and tail
unit it will be have to be painted to match.
A lot of hassle for a daily driver...............
Old Sep 8, 2013 | 11:56 AM
Jeffs82TA's Avatar
Those are for after-market louvers.
Old Sep 8, 2013 | 06:49 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Holy crap guys. Please read the post of what he's looking for and also look at the pics.
The car had aftermarket rear window louvers on it. The hatch screws needed to be removed to install the mount kit and it was just easier to remove the louvers and leave the hardware. Be careful when removing and reinstalling the hatch screws. If you overtighten, you can easily shatter the glass.
The emblems you are looking for will be the tri red emblems. The rear emblem will not have a bowtie, it will just say Z28.
The pic below is not the color you need, but you can see that the rear emblem doesn't have the bowtie.
Old Sep 8, 2013 | 07:10 PM
MACZILLA23's Avatar
Thank you so much! That is exactly what I was trying to ask when it pertains to the emblems. I figured it was that style but wanted to make sure and be sure on the color! I appreciate that very much!
As for the hatch, what your saying is, is that i can remove those pieces in the picture? So I dont actually have to get another hatch?
Thanks again for clarification and understanding what I was asking.
Old Sep 8, 2013 | 07:49 PM
scottmoyer's Avatar
Yes, you can remove those. My suggestion would be loosen one side only. It's possible that they are slotted and slit up under the bolt, then tightened. Also, if you can, get a measurement of the top of the glass to the body if you do have to remove the mounting bolts. This way you can get it back to where it is now. As long as "now" is correct!!
Old Sep 9, 2013 | 01:52 PM
Jeffs82TA's Avatar
I had a set just like them with my louvers. The plates are slotted.
Old Sep 9, 2013 | 10:46 PM
MACZILLA23's Avatar
Pretty easy to take off?
Old Sep 10, 2013 | 11:40 AM
Jeffs82TA's Avatar
just loosen hatch hinge bolts a little and they should just slide out. do one side at a time though.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
