When to connect subframes?
Old Sep 6, 2013 | 03:53 PM
30overTA's Avatar
Car: 1984 Pontiac Trans Am w/T-Tops
Engine: 355 Chevy
Hey guys, how's it going? Newb on this forum but part of several others. I have searched through the forum, cannot find the answer I need...at what point is it necessary to install subframe connectors? What power level is too much for the factory car? I have a 1984 Trans Am with T-Tops, 355 with mild cam, 700R4 with a 2500 stall, no posi rear and sticky tires yet but will this winter. I've heard the T-Tops twist easy but not sure how true that is. Any help or direction to a thread I overlooked is greatly appreciated! Hoping to start the car for the first time this weekend.
Old Sep 6, 2013 | 04:43 PM
JesasaurusRex's Avatar
Re: When to connect subframes?
there's no bad time to do it
Old Sep 6, 2013 | 04:46 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
You will notice an improvement right away if you drive hard.
Old Sep 6, 2013 | 04:47 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I have a 89 GTA with Ttops and I think power level is not the consern. I can hear the body twisting just getting out of the garage. the real question is how hard are you going to drive your car?
I belive that if you have the money you should do it no matter how powerfull your car is or is not. I haven't done it because I can't afford it write now. so the take on this is to drive your car and if you are not happy with how it handles put them on because they will help.
Old Sep 6, 2013 | 06:01 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
they should be put on all cars no matter the engine. the 3rd gen bodies are weak
Old Sep 6, 2013 | 07:28 PM
30overTA's Avatar
Engine: 355 Chevy
I'm a very spirited driver, so do believe I will invest in a set. Thank you!
Old Sep 6, 2013 | 08:07 PM
get a tubular set, that way down the road if you ever decide to put a cage in the car you can tie the D bars into the sfcs and still be legal. Wish somebody had told me that a long time ago when i bought the stupid boxed ones
Old Sep 6, 2013 | 09:24 PM
30overTA's Avatar
Engine: 355 Chevy
Will keep that in mind, thanks.
Old Sep 8, 2013 | 07:35 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Alston frame ties ROCK!
InfernalVortex
Apr 20, 2021 11:31 AM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
