HUGE HUGE PROBLEM
Old Oct 14, 2001 | 07:18 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
HUGE HUGE PROBLEM
Ok, i'm trying to mull my steeing wheel, but the bolts that came with my wheel puller snapped off in the wheel, so I can't use a puller, is there any other way to get the wheel off, this one is on insamely tight. HELP ME!!!!
1989 Firebird 2.8L
Dynomax Cat back
Home made cold air
Bosch +4s
Serious attitude problem.
"There is something cool about going 115 in a car with less displacement than some pop bottles."
Kills: '68 VW bug, 1995 eclipse convertible, some datsun (i swear it was james bond with that smokescreen), 86 pontiac 6000, 84 chevy van, my 84 camaro z/28( with blown trans)
Losses
2002 Viper RT/10 (More like me watching him disappear as i'm waiting for my car to start moving)
Old Oct 14, 2001 | 07:30 PM
BitchinCamaro's Avatar
One way I've done it before (at the risk of a broken nose) is to reach around behind the the wheel and smack it with both hands. (Toward your face.) The wheel needs to come off straight. Good luck
Old Oct 14, 2001 | 07:31 PM
Engine: 4G63T
tried it, and i trued 2 huge screwdrivers prying it.
I'm tempted to put a rope on it and tie the other end to a big truck and...
Old Oct 15, 2001 | 09:12 AM
mcconahay37's Avatar
What kind of bolts were you using? Can you get the old ones out and then try again with stronger bolts like Grade 8 bolts?
Old Oct 16, 2001 | 06:23 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
You may have to get the broken bolts out. There are special drill bits you can use to pull them out, or you can drill them out and retap them. I don't think drilling them out and retapping will hold up to a steering wheel puller though. If everything else fails you might have to cut the wheel it self off. You could probably do this without damaging anything else with the right type of saw. If you can manage this without damaging the grooved part of the column you can just get another wheel.
Old Oct 19, 2001 | 10:24 PM
Undrtkr25's Avatar
I broke my puller too. I just took the nut off and smacked the bolt with a hammer a cpl times. Popped right off. Be carefull though. Dont want any broken speedos.
'89 Chevy Camaro
305 TBI
COMPLETELY stock
Old Oct 20, 2001 | 07:56 AM
I Cant Drive 55's Avatar
One thing I've tried before and it worked.
Loosen the steering wheel nut and back it off untill you reach the end of the shaft.
Leave the nut flush with the shaft so that when you use a brass hammer or piece of brass stock you dont mess up the threads on the shaft. Get someone to pull straight back on the wheel while you tap the shaft.
Sometimes the impact while pulling back on the wheel will jarr it loose.
Old Oct 20, 2001 | 08:00 AM
Also whenever you use a wheel puller tap the center of the puller as you try to pull the wheel . The vibration helps to work the wheel off . And will keep you fromm ringing the bolts off.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
