Where to get a 6 speed console indicator
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Just wondering if anyone sells a 6 speed manual trans indicator (tells where each gear is) to replace the 5 speed one that is on stock center consoles.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
I had a place that makes engraved plaques make me one for my '86 Camaro. Haven't installed it yet since I haven't purchased the tranny. I had them cut me a piece of black painted aluminum to the correct size, then had them engrave the pattern and numbers onto the plate. After they were done I very carefully painted the edge black, being careful not to get any paint on the top. It is adhesive backed and will go right over my 5 speed pattern. If you have a tan interior, you might want to consider using brass instead if you go this route.
Another option would be to have a piece of the same type metal (also used commonly for car show dash plaques) cut and silk screened with the pattern. This would look more stock than the engraving, but would also cost a lot more.
You could also use some glossy decal paper in an inkjet printer, and make one that way. Probably wouldn't hold up near as long, but it would be real easy to redo if it got damaged.
IROCnRoll.com
'86 Camaro Sport Coupe and '88 IROC
IROCnRoll.com
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think SLP might have that. When the original Firehawk was made in 91 & 92 they used a 6 speed, therefore they changed the plate.
Hope that helps.
John
Hope that helps.
John
Why couldn't you pick one up off a C4? They had the ZF6 which was a 6 speed. It would be cheap just go to the junk yard and pry the thing off and slip it into your pocket and go home if you pay for it I doubt they would charge more than a buck. Just an idea.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
91 z-28 305 700R4
3.73 gears out back
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Can't use the Firehawk or C4 shift pattern indicator or **** because ZF is different shift pattern than T56. HOWEVER, you can use a leather C5 Corvette Shifter **** 12559931 (Dealer Net price 37.44). You could use the **** or take the emblem out of it and mount it on the console.
If you get the ****, why go through the trouble of installing the indicator on the console, use it teh way it is, and fill in the console. Some of the console ones I have seen are embossed in the plastic, use some body filler, a little black paint. be creative. Just a thought...
John
John
ummmm....the new camaros and firebirds have 6 speed plate just like our IIRC.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
AIM: IROC 5spd
drain89:
The C5 shifter does have the correct shift pattern on it but has the wrong threads. It will not thread onto the T56 shifter.
I just do not want anyone else to run into the same problem.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's a guy on ebay selling them for the T5 console plate.
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
