Tach not working........
Old Oct 21, 2002 | 06:29 PM
ADMZ24's Avatar
Car: 1991 Trans Am
I replaced my heater core last weekend. I had my friend start the car and I watched for leakage, etc.... Well, he makes the comment, Do you usually have a tach??? I replied, yes, well, the tach is dead. It doesnt move at all. The only thing I can figure is that I might have knocked something loose while working under the hood getting the hoses off of the heater core....... What does the tach run off of. I didnt see anything out of place..... Where should I start??? It is totally dead, nothing, it has never done this before. And, yes, it was working before I started the project....
Help me out here
Old Oct 21, 2002 | 08:50 PM
mgould's Avatar
more bad tach stuff
I don't have an answer for ya, but I have a similar problem. My tach ('90 IROC) reads extraordinarily high. It started this after some work I did on intake manifold (new gaskets,etc.). I actually think it may have something to do with disconnecting/connecting the battery. Did you disconnect the battery when you put new radiator in? I can't seem to chase the electrons in the skematics to determine tach inputs. Let me know if you figure this out.
Old Oct 21, 2002 | 09:03 PM
JAY4SPEED's Avatar
The tach wire wich is white, I believe, needs to be hooked to the negative side of the ignition coil {signal wire that goes to the distributer}. Hope that solves your prob.
Jay
Old Oct 21, 2002 | 09:57 PM
HaroGt14's Avatar
SAME THING HAPPENED TO ME. After about 3 days of it not working, it finally corrected itself and began working. I don't know what it's problem was, but it fixed itself.
Only thing u can do is look on the side of the coil wire to see if u bumped ur tach wire and knocked it off. If not then give it a few days.
Sean
Old Oct 21, 2002 | 11:39 PM
mgould's Avatar
I'll check my wiring again, but this the stock wiring stuff that comes with the TPI and it is fairly murphy proof being modular and all. Distributor has a two-wire bundle that leads to the external coil
Old Oct 21, 2002 | 11:53 PM
The Judge's Avatar
Similiar problem
My tach dont work until I get to 50 mph or If I gas it down it will kick in and start working. But until I get it kicked in the engine misses, but when I get it working the engine runs smooth and good. When I shut the car off the tach just pegs itself.
Old Oct 28, 2002 | 12:08 AM
ADMZ24's Avatar
Car: 1991 Trans Am
Sorry it took me so long to get back. I checked the wire on the coil and it seems to be fine. The tach actually worked a little the other day, it wasnt working right, it was jumping all over, but it did show some life. Any more options??
Old Oct 30, 2002 | 05:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I dunno if mine is different cuz its a 4 barrel, but my tach is connected to the back of the distributor. take a look at the connector maybe? its not too hard to find.
Old Oct 30, 2002 | 08:42 PM
ADMZ24's Avatar
Car: 1991 Trans Am
The tach worked great yesterday. Now it is dead again today. I dont know why it is acting so erratic???
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
