New hood struts didn't help
Hey guy,
I just put on a new set of Sachs hood struts and the hood actually falls more than before?
Do they adjust or is there another trick? The hinges don't have springs so I assume the strut does all the holding.
Thx
Thx
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: New hood struts didn't help
maybe got a bad set, or bought fiberglass struts instead of steel?
when my hood struts were new the hood would damn near lift itself up, i just bought the off the shelf ones at the parts store
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have got them off line before and got bad ones i have better luck with the ones that Oreilly auto parts sells i have them on my car best ones ive had and they are around $14.00 each
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Ya sounds to me like you got a bad set or ones that are too weak to hold the weight. I bought mine off of Rockauto.com and they almost lift the hood on their own. The hatch ones actually do lift it up on their own!
I went with the Sachs specifially cuz I was prepared to pay a bit extra for quality.
I'll reach out to the vendor (off ebay
) and hope they send me another set.
Thx boys, I just didn't know if there was a trick or anything.
Asim
) and hope they send me another set.Thx boys, I just didn't know if there was a trick or anything.
Asim
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
This is a Sachs part number I got from Orielly's for the correct steel hood lift supports.... SG430001 fits 82-92. I think you got some used/bad ones.
Transmission: 5-Speed Manual
If They Are The Correct One's They Would Have Plenty Of Pressure To Hold Up The Hood,They Don't Adjust.
Engine: 305 TBI
I got mine from autozone and put them on the car in the parking lot for the vary same reason...
they have more than 1 part number, it sounds like you have the ones that are for the fiberglass 82-83 hood. They are physically identical. I tried both sets, one would not hold the hood up and the other lifted the hood buy themselves.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
