That Whistling Noise!
Old Oct 26, 2013 | 03:31 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
So, I installed new weather strip for my doors and TTOPS yet I still hear a whistling noise on the freeway and at high speeds. Any ideas?
Old Oct 26, 2013 | 09:19 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: That Whistling Noise!
Maybe the weather stripping needs a while to adjust to your car. What brand did you get?
Old Oct 26, 2013 | 10:15 AM
82tarecaro's Avatar
Maybe you need to adjust the windows and make sure they are seated into the weatherstripping. What brand weatherstripping did you use?
Old Oct 26, 2013 | 10:25 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
ive never heard of a t-top car that didnt have wind noise....
Old Oct 26, 2013 | 10:38 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Mine has never had wind noise.
Old Oct 26, 2013 | 12:14 PM
82tarecaro's Avatar
I just did my weatherstrip - no wind noise.
Old Oct 26, 2013 | 01:04 PM
86iroct5's Avatar
maybe everyones definition of wind "noise" is different but my thirdgen does it so does my friends, my fourthgen does it as well as the numerous other that ive been in.
Old Oct 26, 2013 | 07:09 PM
Scorpner's Avatar
Engine: V6, V8
No means no. Something like that would drive me nuts.
Old Oct 26, 2013 | 07:27 PM
Scorpner's Avatar
Engine: V6, V8
Op, I don't know if these articles help. I had read something on how to install them a while back but not sure if either of these are it or not. Most are based on water leaking in which should be even worse if you have wind noise.
https://www.thirdgen.org/ttops
https://www.thirdgen.org/ttopleakfix
FWIW, the T-Tops were designed with a two zone barrier with the first barrier that opens to a channel that diverts water to the sides. One thing you can do is to try pushing in where ever you hear the noise and see if you can change the sound. You may need a passenger to help with places you can't reach. Once you've found the area where it's leaking then you'll have to figure out what's causing the situation. It could be a simple matter of adjusting the window, or even replacing the triangle seal on the door. Don't try to add silicone or fill in behind it without researching the correct way to deal with it. Most of the time if you try to fix it intuitively it will only make it worse.
Old Dec 18, 2013 | 04:48 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
if you haven't fixed the problem yet I had this issue a while back. this may not be the issue on yours but it fixed mine. the retainers that hold the Ttop pins in weren't low enough in turn not giving the Ttop a good seal. very easy to adjust takes about 5 minutes. might wanna give it a shot. good luck.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
