Source for window channel and front door seals
Old Nov 20, 2013 | 07:19 AM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Got my car back from the body shop this summer and the triangle shaped front window seals were missing. The car is an 83' Camaro, I tried using 87' pieces where the window channel and front window seals are one piece but they won't fit without modification. According to Hawks 82'-83' are different parts. It appears the channel is still in the door but the window seals mount separately? Can't find an 82'-83' in the junkyard around here so does anyone know of a source for these parts? I'm located in San Antonio TX right now. Will also post in Parts WTB., Thanks.
Old Nov 20, 2013 | 09:19 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Source for window channel and front door seals
Send a message to Denny at www.thirdgenranch.com
if you don't see any listed at his site as he prob. has a set.
Sure there gonna be used..........but at a reasonable price vs. new.
Old Nov 20, 2013 | 11:15 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.1aauto.com/1A/Weatherstri...SK00182/260239
and Classic list 82-92 also
Old Nov 20, 2013 | 12:15 PM
1Aauto's Avatar
Former Sponsor
Originally Posted by mantaguy
Thank you ^^^
If you need any help with seals you can shoot me a PM too.
Tony
Old Nov 20, 2013 | 04:50 PM
Engine: 383
Transmission: th350
Originally Posted by 1ATony
Thank you ^^^
Tony
The small seals are just part of what I need. Those are the same on 82-92. The larger triangular parts that mount to the door are specific to 82-83. I already have new small seals that I haven't installed.
Old Nov 20, 2013 | 09:25 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
So HOW did the body shop "miss place" your window channels? I'd be after them to find or replace them.
"Send a message to Denny at www.thirdgenranch.com
if you don't see any listed at his site as he prob. has a set."
I agree with Sonjabb
Old Nov 21, 2013 | 06:56 AM
82tarecaro's Avatar
You can use the 87 triangle but you need to swap out the track also.
Old Nov 21, 2013 | 07:54 AM
Engine: 383
Transmission: th350
Denny got back to me and said to replace the whole assembly with the 87' part. I will remove the channel in the door and try to put in the newer stuff. The body guy in El Paso left his shop so I got a call to come pickup my car and parts. Mostly the weather stripping was off and the roof rails. The body work was good but the car didn't get painted. I took it here and got the paint on it, put on new weather stripping, and now just have aggravating crap like this to finish.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
formula_novice
Aug 18, 2015 08:48 PM
Exxon Limited
Aug 9, 2015 08:13 PM
