my wheels are stuck
Old Nov 25, 2001 | 01:52 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
my wheels are stuck
i bought some 91-92 z28 rims this weekend, i cleaned them up real good, and went to put them on today. when i tried to take off the stock wheels, the rears won't come off. the fronts came off no problem. could the wheel be rusted to the brake drum, or is it something else? how can i get it off?
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
Old Nov 25, 2001 | 02:16 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
I work at America's Tire where I live, and here is what we do to get those off. In fact, we had a 4th gen Trans Am with the exact same problem.
Spray a lot of WD-40 or other lubricant on the surfaces you can get it into. Get a friend with a floor jack to get ready to push it hard from behind the wheel (under the car). Get on your butt and kick back side to side on each end of the wheel facing you as your friend hits it with the jack. This may take a little while and variation of what i said, it will work (unless of course the hub is totally the wrong size and your used a sledgehammer to get it on in the first place).
good luck!
Eric
Old Nov 25, 2001 | 04:56 AM
toosloz's Avatar
just keep kicking the *****
Old Nov 25, 2001 | 05:05 AM
mcconahay37's Avatar
I've found that the easiest way to get stuck wheels off is to apply force at just the right spot. Raise the car so the tire is about 6" or so off the ground. Then, kick diagonally down into the tire so you hit with the side of your foot dead center of the tire halfway between the bottom of the rim and the edge of the tire. This seems to get it on the first or second try 9 times out of 10. If that doesn't work, just try hitting it every way you can until you figure out how to get it off. If you don't understand, I'll draw a picture later.
Old Nov 25, 2001 | 10:25 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Have you backed off the brake shoes by turning the star wheel? You'll have to use a small screwdriver to hold the lever out of the way to spin it back in. Once you have the shoes back in bang the outside of the drum with a rubber mallot. I had a drum on a used rear end I bought that was badly siezed to the axle hub. I drilled small holes at the mating point of the drum and hub until it finally released. Keep spraying with lubricant and drilling until it comes free. You should get a new drum afterwards though.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 25, 2001 | 01:09 PM
jobryan26's Avatar
How to Remove a Stuck Wheel:
Leave Lugnuts off of the Wheel that doesn't seem to want to come off. Then get into the car. Start the car and check for traffic and pull out into the street. Turn your Steering Wheel to the left as far as it will go. Then press the Gas Pedal all the way to the floor. At this time the car may begin to spin around in circles (this is part of the loosening process). Just keep doing this until you feel a large bump, hear a big thud, or hear something that may sound like glass breaking(this doesn't matter right now because you can retrieve the Wheel in a few moments). Now that one of these things have happened remove your foot from the Gas Pedal. The car should slowly stop spinning in circles(NOTICE: You may see the Wheel go flying past you and at this point you know you have successfully removed the Wheel). This is a good time to go and retrieve the wheel(If you can't find the wheel and heard Glass shatter then walk to your neighors house's as the Wheel might be in their Living Room or the front seat of their car, If they aren't home just go get the Wheel and if they are home and refuse to give the Wheel to you, Call the Police and tell them your neighbor refuses to give you your Property) Now that you have gotten you Wheel place it into your hatch. Take the spare tire from the hatch and install it so you can drive safely home(Remember DO NOT drive over 50mph with the Spare Tire install as it is only rated to 50mph. Driving over 50mph could cause you to loose control of your car causing you to wreck or hurt someone. Remeber Safty First). Hope this helps
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Nov 25, 2001 | 01:19 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
hey jobryan26 i tried it your way, and I ended up breaking an axle, getting a big dent in the rear quarter panel, breaking the trans, my lights wont turn on any more, the speedo is stuck at 83 MPH, the radiator is turned 90 degrees from where it should be, the hood turned from teal to purple, and the t-tops switched sides.......what the hell did I do wrong???????????
Oh and the wheel is STILL stuck on the car.
[This message has been edited by mult68 (edited November 25, 2001).]
Old Nov 25, 2001 | 01:20 PM
lonsal's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jobryan26:
</font>
The sad thing is I know from personal experience the method jobryan describes works. I was driving my first 'vert (a 70 Fiat 2000 Spyder) and had stopped at a shop for briefly. When I returned about 5 minutes later and drove out of the parking lot making a left turn a wheel fell off. The only thing I can figure is I surprised someone that was trying to steal the tire. I managed to get the car jacked up and robbed 3 lug nuts from the other rims and was on my way. No damage whatsoever. Thanks for dredging up that memory. 8^(
90 RS Convertible
(626)369-0040
Old Nov 25, 2001 | 01:44 PM
un4givin89's Avatar
you'd be a ****ing idiot to try that ****. All you need to do is remove lug nuts and pull outta your drive way, and then roll over a stacked 4x4 this will loosen it up and the wheel won't come off and you won't kill your car. Use pentrating oil too.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Nov 25, 2001 | 01:47 PM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mult68:
</font>
Sounds like you turned your Steering Wheel to the right instead of turning it to the left. Try turning the Steering Wheel to the Left and try it again and everything should be back to normal. lol
See my Ride:
Old Nov 25, 2001 | 01:49 PM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:
</font>
Dude, it was a Joke! Hahaha, get it? The sad part is someone would prob. try it.
See my Ride:
[This message has been edited by jobryan26 (edited November 25, 2001).]
Old Nov 25, 2001 | 01:55 PM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by lonsal:
</font>
I haven't had a wheel to come off but I almost did once. When I had my '78 Z28 me and a friend was racing down some back roads. Then I started to feel something like my tire was outta balance. I slowed down some but kept going. The bumping got worse and I pulled over and started to look at my wheels and found that all my lug bolts had broken off but 1!. Scared the **** out of me.
See my Ride:
Old Nov 25, 2001 | 04:33 PM
mult68's Avatar
Engine: 305 TBI
Kinda different...but I remeber one time I was working on the rear changing a rear oil seal....got it all back together..wanted to make sure everything was working...I had the passenger side tire off...the other tire on...my dad told me to go start the car and put it in drive and let go of the breaks to make sure the tires would turn....well we forgot to put a couple lug nuts on to hold the rear drum in place....took my foot off the brakes...heard a weird wobbling sound...then the drum cam flying off....scariest thing ever..luckily it didnt hit anything.
Old Nov 25, 2001 | 05:19 PM
jobryan26's Avatar
dang dude that would freak me out too! Hey Diabolical did you get your wheel off yet?
See my Ride:
Old Nov 25, 2001 | 06:03 PM
Chevy83Z28's Avatar
Not as dagnerous as some of you're other stories but my dad was once changing the rear brakes on my brother's mazda (drum rear,) and he after putting it back together with no tires on the car, he had my bro start up the car and pump the brakes. Well, he forgot to put the drum back on the drivers side and the shoes and a million little springs went flying outward. Imagine all the curses and sayings that were said putting that b*tch back together
Old Nov 26, 2001 | 09:52 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
had this problem on a few cars. I usually jack it up and take a piece of wood & a 5 lb sludge hammer. Take the wood an hold it up the the back side of the wheel & hit the wood. if you hit the tire it will only bounce. you have to hit the rim. the wood will keep from marring up the wheel really bad, although it still might.
This seems to be common with aluminum rims.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
Old Nov 26, 2001 | 10:56 AM
chevyboy07 91's Avatar
Well, just looking at the oic in your sig (diabolical) I think you areg onna have a field day getting that whell off LOL. ACtually, just as stated before get a piece of 2X4 and whack the hell out of it w/ a BFH=big fu(king hammer!!!! SHe'll come off the hub
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Nov 26, 2001 | 11:09 AM
bradkeith's Avatar
The reason your wheel is stuck to the hub is because the when water gets inbetween the steel hub and the aluminum wheel it corrodes. I worked at Frank Anderson tire, we had this 85 camaro come in that was driven by a guy who hadn't taken a single wheel off in 8 years, and he parked it outside. It was a SOB to get the wheels off.
1986 camaro with 92z28 gound effects, aero wing, 17in American Racing Pythons w/275'40's 4 3/4 Unlimited products cowl, 3.90 auburn gear rear-end with Steve Spohn adj LCA's,Panhard bar. 406 stroked to to 429 motor in the works.
1989 Iroc-z 5.7 white t-tops, 3.42's megashifter, 2 1/2 harwood cowl.
Old Nov 26, 2001 | 11:17 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
if i have a pita lugnut, i'll make an extension for the lugwrench to try and break it loose( a long piece of metal pipe works well), or stand on the lugwrench and bounce around a bit til it breaks loose.
Old Nov 26, 2001 | 12:06 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Put sulfiric acid in beetween the wheel and the hub. What ever is in there that is holding it on will desolve right off. Hope you dont need those tires. Better do a real good burn out before tring my idea.
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400small block
Old Nov 26, 2001 | 04:05 PM
Diabolical's Avatar
Engine: 305HO L69
<font face="Verdana, Arial" size="2">Originally posted by redbird_400:
Put sulfiric acid in beetween the wheel and the hub. What ever is in there that is holding it on will desolve right off. Hope you dont need those tires. Better do a real good burn out before tring my idea.</font>
hahaha *points at sig*
87 Camaro LT
mods to come:
ground effects
93 camaro seats
91 z28 rims
Old Nov 26, 2001 | 06:56 PM
SlowCamaro88SC's Avatar
this is what happens when your wheel flies off. though mine was a bit different. I still haven't fogiven my father for what he did to me. btw, the iroc is still sitting there.
https://www.thirdgen.org/messgboard/...ML/001175.html
Old Nov 26, 2001 | 08:26 PM
jobryan26's Avatar
Oh **** man I'm glad you're ok.
See my Ride:
Old Nov 27, 2001 | 05:30 AM
poncho9789's Avatar
</font>
I tried that once and yes it does hurt your car. when you run over it and it wedges up under the rocker panel and puts a horrable dent in it.
just use some penitrating lube (luqid wrench) and let it set for a while and then try kicking it off.
Old Nov 27, 2001 | 08:15 AM
VampireHunterC's Avatar
I had a wheel come off once. It was in my first car, a '76 Toyota Corolla. I was taking my friend home at, like, 2 in the morning. Wham! Left rear drops a foot and sparks go everywhere! I thought that I had hit a pothole and broken a strut or something. Got pulled over and noticed that the wheel was missing. My dad found it the next day about a mile up the road.
Old Nov 29, 2001 | 05:56 PM
MaroonZ28's Avatar
that happend to my dad and us b/f we were in our 67 fastback mustang gt and we stopped 2 get sumtin in a store and we came out and some 1 had taken off the lugs,tryin 2 steal it,but we must have scared them off we got in the car and down the hway goin bout 60 and the tire fell out and made us spin out like 3 times,later we found the wheel rolled down the road about 2 miles through trafic lol, it smashed the rear quarter and compacted it. but we were all fine but we never found the lugs, or the A$$hole who loosened our lugs
goin on 16 and i want a 3rd gen!
~cars~
1991 camaro z28
(will be mine soon hopfully)
1967 mustang gt fastback
(mine&dads)
1968 Shelby cobra gt500kr
(dads)
goto 4 pics
my_cars
Old Nov 29, 2001 | 10:44 PM
killer305's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SlowCamaro88SC:
</font>
what ever happened to your car, and what about the cops, man that story sucks, your dad is a ****, you had every right tp push him, if its not a girl, or abouve like 70 then its okay in my book, but some acceptions aply, ie, parapalijics(sp}
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player,autometer phantom gauges, soon to have 91-92 gfx, z-28 wing, new paintjob, rims, all new suspension, and new inteior
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
