Windshield Motor Problem
Old Dec 28, 2013 | 07:15 PM
M3638's Avatar
Car: 1990 Iroc Convertible
I completely gutted my engine bay and I'm in the process of putting back together. I went to install the wiper motor but there is a gap between the firewall and where it's suppose to have a grommet or some type of "rubber piece". Mine fell apart (grommet/rubber piece), when I took it off. I've searched the forum, looked it up at the Autoparts stores and nothing. Anyone know where I can get one?
Old Dec 29, 2013 | 11:13 AM
M3638's Avatar
Re: Windshield Motor Problem
Bump
Old Dec 29, 2013 | 11:17 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
if you cant locate one, you could try to make one out of some hose, or try to get an o-ring to fit it ... not sure how big the gap is though
Old Dec 29, 2013 | 12:33 PM
Joe Tag's Avatar
They're called isolators. I did a quick search and found these that may work. You'll have to call the company and get dimensions if you can to be sure.
http://www.avsontheweb.com/product.p...cat=925&page=1
Old Dec 29, 2013 | 01:03 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Hmmm, I had to take the rubber pieces OFF the windshield motor in order to make it fit when the SuperRam went on. It still bolted to the firewall just as well as it did before.
Old Dec 29, 2013 | 01:18 PM
Joe Tag's Avatar
They're there to dampen vibration noises from the motor. It will mount like that but it will be noisy.
Old Dec 29, 2013 | 02:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.clipsandfasteners.com/Gro...rial_s/103.htm
Old Dec 29, 2013 | 03:35 PM
M3638's Avatar
I really appreciate the replies,,, Ill look into this tomorrow. And yes it will bolt on with no problems, there is just that gap from the wiper motor to the firewall in the center. Thanks again for the ideas and info.
Old Dec 29, 2013 | 03:39 PM
M3638's Avatar
If you can see the picture,,, I have three bolts where the wiper motor would go.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
