Pics of rocker panel
Old Jan 21, 2014 | 03:49 PM
Clausoe's Avatar
Hi,
I'm repairing som old rust damage due to incorrect placement of a Jack on the front passenger side rocker panel.
The area is so damaged so I dont really know what shape it originally had. I've included som pics of the damaged area.
I was hoping someone has some pictures of this area form underneath so I could see, I've been searching the site forever but didn't quite find what I needed.
I'm basically wondering if the pinch weld line should be completely straight from front to back, both horisontally seen from the side and seen from rear towards the front from below, (I know the area the front fender is attached extends below the line of the pinchweld).
A pic of the passenger side front rocker panel seen from the side would also maybe help.
Old Jan 21, 2014 | 03:53 PM
Clausoe's Avatar
Re: Pics of rocker panel
Pictures
Old Jan 21, 2014 | 04:21 PM
marki's Avatar
Car: 92 camaro rs
Engine: 305 t.b.i.
Hi, if i am correct the pinch weld should go in a straight line from the front tire to the rear tire. Do you have a rust hole near the pinch weld area? I currently have a semi large hole right behind the passenger side front tire on the pinch weld from the same thing someone jacking it up wrong and bending it. I am not sure replacement rocker panels come with the pinch welds or not. If you have a replacement rocker panel please let me know if it has the pinch weld.
Mark
Old Jan 23, 2014 | 03:02 PM
Clausoe's Avatar
You can just see the hole in the picture I posted, seems like we have the same damage but i will just make a square patch an weld it in.
Can someone tell me the thickness of the pichweld area plate that the rocker is welded to?I tryed to measure it, seems like 0'8 mm, correct?
Old Jan 30, 2014 | 10:58 AM
Clausoe's Avatar
Well here come the repair pics for those who like body work Basically three steps, straightening, cutting out for replacement panel bits, and welding. Turned out the rust extended up past the floorboard so the piece I welded in reaches from the pinch weld at the bottom , past the floorboard pinchweld an is welded to inside panel that makes up the cavity inside the rocker panel, so it is pretty much as it is from the factory. Just needs Paint and sealing.
Attached Thumbnails Pics of rocker panel-wp_001474.jpg   Pics of rocker panel-wp_001475.jpg   Pics of rocker panel-wp_001476.jpg
Old Jan 30, 2014 | 11:00 AM
Clausoe's Avatar
More
Attached Thumbnails Pics of rocker panel-wp_001481.jpg   Pics of rocker panel-wp_001483.jpg   Pics of rocker panel-wp_001484.jpg
Old Jan 30, 2014 | 11:02 AM
Clausoe's Avatar
Last two
Attached Thumbnails Pics of rocker panel-wp_001487.jpg   Pics of rocker panel-wp_001488.jpg
Old Apr 6, 2014 | 02:18 AM
Clausoe's Avatar
Final pics. Ended up needing to make 2 spacers for the lower rear part of the fender to line up with the rocker panel. Didnt really understand why this is so now that the pinch weld is all in a straight line from front to back - well well, its done
Attached Thumbnails Pics of rocker panel-wp_001490.jpg   Pics of rocker panel-wp_001540.jpg   Pics of rocker panel-wp_001541.jpg
Old May 20, 2014 | 06:20 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Nice work man. I have to make an almost identical repair to my car. The pinch weld was bent over years ago and the rocker has rusted through. I will use your pictures as a guide on what to do!
Old May 20, 2014 | 07:00 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Subscribing to this! Maybe other can post pics of their rocker fixes! I'm about to take on a big project myself, so anything helps!
Old May 20, 2014 | 09:39 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Nice job and looks like a nice 68 442 sitting beside your car
3.8TransAM
Sep 3, 2015 06:38 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
