new paintjob... IDEAS!
Old Dec 10, 2001 | 11:40 PM
Fast86TA's Avatar
ok, this may sound a little crazy...... ok, a LOTTA crazy, but I was just kinda thinking, couldn't you take that spray on truck bead liner stuff, and spray an entire car in it, and sand that stuff smooth, and clear coat it, and ave a nice new black paintjob that will help keep the car from rusting a little better? please help me, I'm just kind of brainstorming here....
Old Dec 10, 2001 | 11:42 PM
HamsterOnaMission's Avatar
sounds like it would work... would paint adhere to it though??? (using it like a sealer right?)
Old Dec 10, 2001 | 11:47 PM
Fast86TA's Avatar
well, most of that stuff says it's paintable.. and I wasn't going to paint it anyway, just clear coat it, it's already black, and I want it to be a black car, and the clearcoat would make it kinda shiney... I'm not sure....
Old Dec 11, 2001 | 12:06 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Get a hunk of scrap metal, give 'er a go, see what happens...
Old Dec 11, 2001 | 10:57 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Why not use POR15? It's paintable, available in High-gloss, and prevents rust. My whole underbody and fenderwells are getting a coat of it soon so these St. Louis salt roads don't get to my frame and such.
-Matt
POWER AT THE COST OF BODY WORK...
1984 Camaro Z28 - Black w/ Grey int.
-GMPP 350 (72cc heads, 8.5:1 CR, & .390 intake/.410 exhaust cam) with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics & more at: http://members.fbody.com/flashz28/
Old Dec 11, 2001 | 12:48 PM
bradkeith's Avatar
The spray on bed-liner idea would never work. I sprayed the bed on my 86 chevy truck with that stuff about a year ago. It is made of all kinds of crap like rubber and asphalt. It would be a pain in the axx to sand it down smooth enough to get a good-looking paint-job. If you do decide to try it let us know how it turns out, I'd be interested.
1986 camaro with 92z28 gound effects, aero wing, 17in American Racing Pythons w/275'40's 4 3/4 Unlimited products cowl, 3.90 auburn gear rear-end with Steve Spohn adj LCA's,Panhard bar. 406 stroked to to 429 motor in the works.
1989 Iroc-z 5.7 white t-tops, 3.42's megashifter, 2 1/2 harwood cowl.
Old Dec 11, 2001 | 12:54 PM
RSRagtop's Avatar
I wouldn't do it. If that stuff looks bad after its on, it will be a PITA to get it back off the car. Think about it,the stuff is supposed to protect a truck bed that gets used and abused.
Old Dec 11, 2001 | 10:07 PM
SgtSkip's Avatar
I just saw a PT Cruiser with the lower pannels like you're thinking and was clear coated. I didn't really like it. Then again, I don't like PT Cruisers either!
85T/A 305/QJ work in progress.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
