problems lining up
Old Dec 14, 2001 | 07:24 PM
88greyiroc's Avatar
problems lining up
my car is an 88 iroc and the right side door seems like it is sunked in more then the front fender.and the rear of the door hits on the groundeffects i was wondering could this be a sign the fender is out or could the frame be twisted?and on the left side my molding on the door does not line up on either side it is lower than the front and rear moldings on the fenders.but i am hoping it is just the hinges and pins because the doors do close hard.and if so would it cost much to get a mechanic to fix them?how many hours?
1988 Iroc-z (Gun MetaL)
350TPI (38K MILES)
700r4 stage 2 shiftkit
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 14, 2001 | 07:41 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
It sounds like the door hinges are just worn out.The doors are normally about 1/4" to 5/16" below the fender.
Old Dec 14, 2001 | 09:38 PM
88greyiroc's Avatar
ok good i hope so someone told me that you can tell if your frame is bent by how your doors line up.
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
wayshegoes
Aug 17, 2015 12:00 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
