OH BOY
Old Feb 17, 2014 | 10:44 PM
first3rdgen's Avatar
Car: 88 camaro
Transmission: 5 speed
Axle/Gears: 3.08
OH BOY
its happened again I knew id end up with another one of these cars but I think im going try to put this one back to its former glory rather than wanting to make a hot rod shes pretty beat up but has new fuel system and very little rust and is set up with a lot of things I wish my old rs had. but I need some help determining what this car is and what ground effects I need to get it doesn't say rs anywhere and its not a z28 just wanting to make sure I start buying the correct parts any help would be appreciated greatly im posting here do to the fact im needing help with figuring out what body parts I need if it is in the incorrect location I apologize
Old Feb 19, 2014 | 01:53 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: OH BOY
Alright....I'll deal with this run-on sentence since no one else will.
Being an '88, it pre-dates RS models...and with no G80 limited slip rear on the RPO sticker, I'm going to have to say it's a base Sport Coupe. Looks like someone has added an IROC hood, and you're missing the ground effects for the front fenders/front bumper.
Pretty desirable car as far as non-IROCs go though, it's a real Black/Black t-top 305/5 speed car with lots of options that are usually not on base model cars.
Old Feb 19, 2014 | 06:14 PM
Car: 88 camaro
Axle/Gears: 3.08
Re: OH BOY
I appreciate the reply I was begging to wonder if no one cared to help out a fellow enthusiast. As for my grammar I apologize I will attempt to do better. The main question I had was are the ground effects the same as the rs? I'm in need of more than just the fender ground effects and chin the farmer that had it before drug a plow across the front end and all the ground effects were thrashed.
Old Feb 19, 2014 | 08:14 PM
Steve86TA's Avatar
Car: To many to list
Re: OH BOY
All 85-90 RS or Z28 ground effects are the same
Old Feb 19, 2014 | 10:04 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
False.
85 thru model year 1990 built in 89 (IROC) share the same gfx. Cars built after jan 1 1990 were not IROCs. They were the Z28 with the newer gfx, hood blisters and big spoiler.
GM lost the iroc nameplate for 1990 so only cars built in 89 could wear it. The 90 IROCs do have the yellow gauges.
Old Feb 20, 2014 | 09:14 PM
Steve86TA's Avatar
Re: OH BOY
To the OP.. as I said you need 85-90 GFX..91--92 are different
Old Feb 20, 2014 | 09:47 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
That's not what you said... technically.
But you're right.
Old Feb 21, 2014 | 06:48 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Re: OH BOY
RS models started in 1987 in California only. They came in red, white and black.
Elephantismo
Feb 13, 2019 12:51 AM
85cmroz28
Oct 4, 2015 09:44 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
